Question about Optics
Where can I buy a seal for the Crossman .177 pistol
When I install the co2 cartridge it hisses.Must be leaking.Where can I buy a seal?
Hi, I am trying to remove a brand new CO2 cartridge I just put in a new Gamo PT-85 Blowback pellet hand gun. As I'm unscrewing it, gas is leaking out. HELP.
Hello K Brink,
Kind of like deja vous (all over again )...
Pretty sure: This is the same Question I answered
yesterday (no / yes? ).
There is no going back... Once the CO2 cartridge is
pierced... there is no way to salvage the cylinder
until it is FULLY expended...
If you unscrew the chamber the CO2 will ALL be released.
Just ONE word... If your cylinders are depleted... ALWAYS
check that the SEALING O-ring stays with the hand-gun.
Just make sure yur SEALING RING is still in the "gun"
and NOT STUCK to the ... co2 CARTRIDGE.
I am just saying...
((been there... Done that))...
Carnac the Magnificent
Nov 29, 2017 | Gamo Optics
Hello K Brink,
I am just saying...
Gun was working fine, now will not fire even with new co2 cartridge, any suggestions
It is possible the 'new' CO2 cartridge is defective.
If the gun was working fine BEFORE you installed the new CO2 cartridge, try a different cartridge.
Maybe the seal wasn't pearced on the new cartridge. Also, a blockage would also prevent the gun from firing. Check the gas pathways for a blockage.
Aug 13, 2015 | Miscellaneous
My Crosman 1008 Repeat Air pistol leaks all CO2 out
The crosman 1008 does indeed fire pellets! NOT BBs. ONLY pellets.
Feb 03, 2014 | Crosman (4032)
Co2 install
Your seal is probably out...
Jul 29, 2013 | Crosman Optics
When i instert the co2 in my airmag c11 it just releses all of the co2 and its all wasted what do i do???
Take a short strip of teflon tape and put it over the end of the co2 cartridge, make sure its in straight and tighten, works good.....:)
May 03, 2011 | Crosman (4032)
Air leaks out when installing co2
The Phantom Break-Barrel does not use CO2. It is a spring-loaded break-barrel weapon. If you really do have a CO2 gun, check the rubber seal around the outside of the cartridge puncture needle.
Feb 18, 2011 | Crosman Phantom .177 Caliber Break Barrel...
After inserting and compressing the CO2 cartridge, the CO2 leaks
You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
Jul 12, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Optics Logo
43 people viewed this question
Top Optics Experts
james laughton
james laughton
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
