Question about Apple Power Mac G5 Desktop
Screen switches from application back to desktop
When performing any application, the screen automatically jumps from the application to the desktop. All folders and desktop icons briefly dissapear then reappear.
  • 1 more comment
  • stephenmv Jan 14, 2009
    My screen has just started doing exactly the same thing. I'll be half way through writing a sentence and the screen has switched to the desktop. I have to click back on the document to start writing again. It seems to happen randomly, even when I'm doing nothing with mouse or keyboard. As hankmc897 says, the icons on the desktop disappear for a second when it does this.
    FYI, I also just connected my Apple Express and updated software - could this be a factor?
    Thanks in advance!
  • Anonymous Jan 29, 2009
    I have the same problem. It's not the keyboard, I've checked.
  • David Lawrence Feb 02, 2009
    Exactly as Hankmc897. Exposé/Dashboard does not fix problem. Tried repairing disc/permissions, rebooting etc. Virex running OK
Allanster's solution worked for me straight away:
system preferences/other/Stuffit AVR/ then click stop button for 'Stuffit ArchiveViaRename
Posted on Feb 02, 2009
    Problem Solver:
  • 9 Answers
Open your System Preferences. Go to Dashboard & Expose. This is a very helpful application in my world. Whenever you want to see all the windows, hide windows, start screen saver, you just push your mouse into the appropriate corner. Sounds like you have a corner set and when you hit it, you trip the effect. Change the corner and check them out, Handy to use when you have multiple windows open. Experiment and see.
Posted on Jan 06, 2009
Errror message JVM error 102 appears on screen
Problem
The BlackBerry smartphone stops responding and displays the following error message:
JVM Error 102
Cause
A problem exists with one or more of the .cod files on the BlackBerry smartphone.
Resolution
Before completing this resolution, download and install the latest version of BlackBerry® Device Software from your service provider's web site.
Re-install the BlackBerry Device Software and applications to your BlackBerry smartphone by completing the following steps:
Warning: The following procedures will delete either all data or all data and applications from your BlackBerry smartphone. Back up your data before performing the procedure. For instructions, see KB12487.
Connect your BlackBerry smartphone to your computer.
Open BlackBerry® Desktop Manager. Note: BlackBerry Desktop Manager may display "Disconnected." If this is the case, proceed to the next step to correct the problem with Application Loader.
Click Application Loader. The Application Loader Wizard appears.
Click Next.
Choose the port that the BlackBerry smartphone is connected to and click Next.
If prompted, type your BlackBerry smartphone password and click Next. The Device Application Selection screen appears.
Select the applications that you want to install on your BlackBerry smartphone.
If the Device Backup screen appears, choose whether or not to automatically back up the data on your BlackBerry smartphone. Click Next.
Click Next.
The Completing the Application Wizard screen appears, displaying all the software that will be installed on your BlackBerry smartphone. Click Advanced and make sure that Erase all application data and Erase all currently installed applications are both selected.
Note: If the application loader tool was not able to access all of the data on your BlackBerry smartphone, then the following two fields are grayed out: Erase all application data and Erase all currently installed applications.
Click Next.
Select Do not automatically create a backup and click Next.
Click Finish. The BlackBerry Device Software will be installed on your BlackBerry smartphone. Do not disconnect your BlackBerry smartphone until the process has completed.
Axl
May 04, 2010 | RIM BlackBerry Bold 9700 Smartphone
Tip
Factory Reset for Centro and Treo 755p
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone. Press Applications to exit the Security application.
3.Now that a system password is established, we'll perform a hard reset to complete the factory reset. With the device face down, remove the battery door. Removing the stylus may make it easier to remove the battery for the next step.
4.Remove the battery. Then put the battery back in.
5.When the Palm logo appears, press and hold Power/End until the black status bar at the bottom of the screen fills and disappears, and then release Power/End.
6.If you performed this reset correctly, you should see a white screen with black text saying "reformatting in progress" (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again). Your smartphone will appear to reset again after the "reformatting in progress" screen disappears.
7.When the Erase all data? prompt appears, press Up to confirm the Factory reset.
8.When the language selection screen appears, select the same language you selected for your desktop software. The Factory reset is now complete.
on Mar 11, 2010 | Cell Phones
Jvm error 102 on screen of my curve in phone is not working keeps on
The BlackBerry smartphone stops responding, and the following error message is displayed: "JVM 102" There is an issue with one or more of the .cod files installed on the BlackBerry smartphone. To resolve this issue, perform a clean reload of the BlackBerry® Device Software on the BlackBerry smartphone using the application loader tool. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps: To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications to be loaded, and then click Next. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Clear the check box next to Backup up device data automatically during the installation process. Click Ok > Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following: Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 20, 2009 | AT&T Blackberry Curve 8300 Smartphone
I have reload sofware 513 on my bb 8900 screen and I have tried to plug it to my computter and my computter doesnt recognise it.
Hi, After typing the incorrect password ten times and restarting the BlackBerry smartphone, the error JVM 513 appears: This error occurs because all of the data and applications on the BlackBerry smartphone have been deleted. The BlackBerry Device Software must be reloaded on to the BlackBerry smartphone. To reload the BlackBerry Device Software you need the complete the following steps: Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps: To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications to be loaded, and then click Next. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Clear the check box next to Backup up device data automatically during the installation process. Click Ok > Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following: Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. Hope I helped you. Thank you for using ' Fixya ' and have a nice day!! .
Nov 17, 2009 | RIM BlackBerry Storm 9530 Smartphone
I have the jum error 102 on my blackberry pearl however my phone occasionally returns back to normal why?
Hi, The BlackBerry smartphone stops responding, and the "JVM 102" error message is displayed: JVM 102 error occurs when there is an issue with one or more of the .cod files installed on the BlackBerry smartphone. To resolve this issue, perform a clean reload of the BlackBerry Device Software on the BlackBerry smartphone using the application loader tool. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps: To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications to be loaded, and then click Next. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Clear the check box next to Backup up device data automatically during the installation process. Click Ok > Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following: Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Pearl 8100
ITS JUST STUCK ON THE SCREEN I CANT DO ANYTHING MY BLACKBERRY CURVE 8310 IS STUCK WITH THE ERROR CODE JVM ERROR 102
Nov 13, 2009 | RIM BlackBerry 7290
JVM error 513
After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:JVM 513
The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone.
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
Oct 28, 2009 | RIM BlackBerry Pearl 8100
I get app error 523 every time on my blackberry 8220 pearl flip display
On the BlackBerry smartphone, the following error message appears after pressing the Mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, first perform a hard reset.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If this does not resolve the issue, the BlackBerry® Device Software must be re-installed.
  2. Click Help.
  2. Click Next.
The BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to open and run the application loader tool.
If BlackBerry Desktop Manager cannot connect to the BlackBerry smartphone, perform the following steps:
  1. Remove the battery and run loader.exe from C:\Program files\Common Files\Research In Motion\AppLoader.
  2. Remember to reinsert the battery after the loading operations begin.
Oct 26, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
How to reset blackberry7290 its pop up on the screen error reset 532 when i push the scroll before its operated im on the mood of exploring the phone i change the language from english i turn to portugues...
smartphone.
1) Open BlackBerry Desktop Manager.
2) Click Help
3) Select About Desktop Manager.
4) Click the Device Software tab.
5) Verify that the BlackBerry Device Software displayed is the latest
1) Connect the BlackBerry smartphone to the computer and open
2) Double-click Application Loader.
3) Click Next to start the installation process.
4) Type your BlackBerry smartphone password, if prompted, and click
OK.
5) Select the check boxes next to the names of the applications to be
6) Click Settings, and then select the check boxes beside Delete all
7) Clear the check box next to Backup up device data automatically
8) Click Ok > Next > Finish.
9) When the process has completed, the message The loading
1) Click Advanced , and then select the check boxes beside Erase all
2) Click Next.
3) Select the check box next to Do not automatically backup the
4) Clear the check box next to Backup and restore applications
5) Click Next > Finish.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to open and run the application loader tool.
1) Remove the battery and run loader.exe from C:\Program
2) Remember to reinsert the battery after the loading operations begin.
Oct 24, 2009 | RIM BlackBerry 7290
Blackberry flip jvm error 545
  2. Click Help.
Warning: The following procedure will delete either all data, or applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
To perform a full backup of the BlackBerry smartphone data complete the following steps:
  1. Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Click Backup and Restore.
  4. Select Backup to perform a full backup.
  5. Select a location to save the backup file, and then click Save.
To perform a selective backup for one or more databases perform the following steps:
  4. Click on Advanced.
  5. Select the database(s) on the right side selection window for Device databases.
  6. Select the Arrow that points to the left side of the screen to transfer the database(s) to include in the backup.
  7. Verify the database(s) are on the left side selection window for the Computer databases.
  8. Click on File in the menu located at the top left hand side of the Desktop Manager.
  9. Name the backup file and select a location to save the file.
  10. Click the option to Save once the location for the file is selected.
Once you perform backup procedure, kindly then perform the following steps:
  • Click Ok > Next > Finish.
  • When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
  • To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
    2. Click Next.
    Oct 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
    Apple Power Mac G5 Desktop Logo
    61 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
