Question about Kenmore Elite HE4 Electric Dryer
Heating element for kenmore dryer won't turn on
I've removed the lower front panel, to observe, turned the dryer on(allthe different settings), and the heating element won't heat up
Hi, I have an 11yr old 80 series elec. dryer and just fixed the same problem. On the heater element is a thermostat with 2 wires and above that about 14" is another piece with 2 wires. I had to replace the top one. They sell them together in a kit called Thermal cut off kit. Sears sell it for 25.49 look up part number 279816 or 3399848 again these numbers are for my dryer but you can look them up on the sears parts web site. If you have a sears service center near by they let me buy the parts to see which one it was and then return the ones I didn't need. I hope this helps.Good luck
Posted on Jan 06, 2009
Replacing heating element in Kenmore model 110.65922
The heating element will have multiple coils to it with two leads coming into it. POS/NEG. If that is it then it is very strange that it is not enclosed in some way shape or form.
Feb 12, 2014 | Kenmore Dryers
Kenmore series 80 electric dryer won't heat
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath.
May 28, 2012 | Kenmore Dryers
Will not start
It's very likely that your heating element is shorted and will need to be replaced. Unplug the dryer and remove the lower front panel. There are 2 spring clips between the upper front panel and the lower front panel. Use a flat screwdriver and slide it over these clips and then pry these clips down to unclip them so that you can hinge the bottom panel down and then off. The heating element is in the bottom right corner inside the silver heating canister. There is one screw coming in from the left holding the element inside the canister. Remove the screw and remove the front panel of the heating canister. Disconnect the wires to the element and then the element will pull straight out. Here is a link to the part.
http://www.repairclinic.com/PartDetail/Heating-Element-Assembly/3387747/525502
Thanks
Jun 21, 2011 | Kenmore 63942 Dryer
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
No heat, but dryer turns.
There are three common causes of a dryer not heating. First is a busted heating element. Second, the thermal cut-off has blown. Third, the high limit thermostat is not working.
Disconnect power to the machine and remove the screws at the bottom of the lower front access panel (toe panel) holding it in place. Pull the panel down and off the cabinet. You now have access to the heating circuit.
Remove the heater shield by removing its mounting screw and pulling it off the heater housing.
The heater terminal block is located at the left opening of the heater housing. Disconnect the wire from one of the heater terminals and measure the resistance of the heating element using an ohmmeter set to X1. The resistance should read 7.8 -11.8 ohms. Replace the heating element if the resistance reads open.
Disconnect the wires from the terminals of the heating element and remove the screw securing it to the heater housing. Slide the busted heating element out of the housing and install the new heating element. Secure it with the screw and put the terminal block in place. Connect the heater wires and reinstall the heater shield.
Slide the lower front access panel up into the cabinet and secure it with the screws.
Feb 28, 2010 | Kenmore Elite HE4 Electric Dryer
How to test heating element in kenmore h3 dryer
You can test the element while it is still installed if you like. Just make sure the dryer is UNPLUGGED, first. Dangerous voltage is still present with the dryer turned off. Remove the lower toe panel under the dryer door. This is accomplished by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the dryer up can provide better access. Placing the feet on a 2x4 works well for this).
You have to remove the blower fan housing to better access to the heating element. Make sure you reach inside the door and remove the lint screen first. Then, remove the screws holding the assembly in place and remove.
Disconnect the wires from the heating element before taking any measurements. This ensures your readings are accurate and you do not read any parallel resistance paths. Do a resistance check across the heating element terminals making sure you do not ground your leads to the element heater box. A good reading will be between 9 and 13 ohms. If you have any questions, please let me know.
NOTE: This is a good time to clean the dryer interior and blower fan, while you have everything removed.
Nov 15, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I'm trying to install a new heating element to my Kenmore dryer 80/90 series. The rear panel does not come loose after I remove all the screws. I need this to come off to install the heating element. Tks
Replace screws at rear exactly as they were. Entrance for this dryer is at the lower front panel.
Unplug unit first. Place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the panel. This will release the lower panel and give you full access to all the main components.
The heater is on the right in the metal can with the cover at the front. On the left side of the can is a thermal fuse that may be open to turn off the heater. There is also a thermostat that may be bad or interconnecting wiring. Remove cover at the front of the can and disconnect wires to element.Element should slide out for replacement. Look for screws retaining it if it doesn't.
Reverse above process for reassembly. Good Luck.
Sep 10, 2009 | Kenmore 63942 Dryer
Kenmore 84152
On a kenmore conventional dryer they had for a million years the heating element is on the rear of the machine on the right. Some newer models "princess type" have a lower front panel and a heater that just yanks out for easier servicing.
Jan 20, 2009 | Kenmore 84152 Electric Dryer
Kenmore dryer model 96273100 no heat.
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
Based on the model number you provided, I'm assuming this dryer can be accessed by removing the back panel.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
I hope this information is helpful to you. Post back if you have any further questions, or need assistance in finding replacement parts.
May 08, 2008 | Dryers
Replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
Dec 08, 2007 | Kenmore 64892 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
306 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
