Question about Plantronics Radio Communications
I can not hear anything in the headset cs540 plantronics
keekus
  • 83 Answers
SOURCE: I am getting feedback with Plantronics CS70 Wireless Headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Posted on Jul 18, 2009
keekus
  • 83 Answers
SOURCE: plantronics CS55. When using the wireless headset
keekus
  • 83 Answers
SOURCE: Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Posted on Jul 20, 2009
  • 10 Answers
SOURCE: Can barely hear on full volume? Plantronics 232
1. Stay away from ambient noises 2. Press the up volume for 3 seconds. 3. Make sure it's in your ear all the way.
Posted on Jul 22, 2010
wb91
  • 126 Answers
SOURCE: I recently purchased a plantronics
This is a common problem if you are using a 2.5mm patch cable instead of the Vista M22 amplifier. Phones do not put out enough power to the 2.5mm jack. If you are using the Vista M22 amplifier make sure the batteries are fresh and installed correctly. Also sometimes a voice tube can become clogged with debris which can restrict the airflow and people will not be able to hear you.
Good Luck from Headsets Direct!
Posted on Apr 14, 2011
I want to buy Plantronics CS-540 online. Recommend a credible website.
Well buying Plantronics CS540 is an excellent choice. You can find various websites online which are offering Plantronics headsets online. I do not know your geographic location but if you are in US then I would suggest that you should check HeadsetZone, Telegiants.com as they usually offer headsets at the most affordable price.
Plantronics CS540
Plantronics CS540
Apr 26, 2017 | Plantronics Radio Communications
Trouble using Plantronics CS540 headset with N594 phone...are these compatible
Check what protocol the devices use and accept. There are about 10 protocols from 1.0 to 4.2 sometimes they are not comatible at all.
Learn more here:
Bluetooth Wikipedia the free encyclopedia
Apr 01, 2015 | Plantronics Radio Communications
My headset will not charge fully and after a couple of hours needs re charging light does not flash for long
If it's old then the battery has probably worn out and no longer holds much charge. See if it can be replaced.
Dec 29, 2014 | Plantronics Cs540 Wireless Headset
How can answer the calls away from the desk if I need to push the answer botton on the phone?
The little silver button on the side of the headset is how you answer calls when using the headset, when you get a call just press the button, this is also how you hang up
Oct 07, 2014 | Plantronics CS540 with HL10 Wireless...
Headset troubleshooting
I can hear the caller but they can not hear me...what is the solution?
Jul 15, 2014 | Plantronics Cs540 Wireless Headset
Cs540 caller hears echo
Hello, if they are hearing echo, you are speaking too loud. Or have the receiver too close and talking too loud. Or the person on the other end of the line has phone line problems.
May 16, 2014 | Plantronics CS50 Wireless Headset
Headset won't charge
This is going to be the charger or the battery. I am going to bet that that charger went bad it this is not that old.
Nov 15, 2013 | Plantronics Cs540 Wireless Headset
I hooked it up to my ps3 but i can't hear any volume from the game. i ahve an adapter. the mic works but i just can't hear anything
Per Plantronics the Gamecom 367 headset is not compatible with the ps3. Plantronics did say the Gamecom 777 will work with the ps3. Please see the link below for the Gamecom 777.
Plantronics Gamecom 777
Good luck from Headsets Direct!
Apr 24, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
Radio Communications Logo
55 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
