Question about Whirlpool WGD7800X Cabrio Steam 7.6 cu. ft. Gas Dryer
WGD7800 XWO twice now the blower wheel pulley has had to be repaired. The tech said that model has been discontinued & no parts avail, Said it was a bad design & I should consider buying a di
Has this model been discontinued & no parts avail.? Was it a bad design & should I consider a new machine. He said they tried a different technology & it didn't work. Is this true?
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: need to know if I can get parts and what part #'s available for Whirlpool/ Roper electric Dryer lme4600w2. For blower wheel,blower wheel belt, idler pulley, & drum belt.
Hi Alisa Wilkerson...
Try one or both of these on-line websites...they also have phone support (free)
1... http://www.appliancepartspros.com/ (1-877-477-7278)
2... http://www.partselect.com/ (1-888-895-1535)
Good luck, I am sure they will be able to help
Bud
Posted on Sep 21, 2012
Need to know if I can get parts and what part #'s available for Whirlpool/ Roper electric Dryer lme4600w2. For blower wheel,blower wheel belt, idler pulley, & drum belt.
Bud
Sep 21, 2012 | Whirlpool Dryers
My whirlpool awz 7303 is very noisy. i think it is something to do with the drum going round. could the belt need tightening?
If your dryer is noisy, check these: Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing assembly does not fail often in this type of dryer. There are videos of the testing and replacing of these parts at http://appliancehelponline.com/dryerrollervideo.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there. All parts come with installation instructions. Not all models are available.
Sep 13, 2010 | Whirlpool AWZ7303 Electric Dryer
Dryer squeeks when drum is turning,gets very loud after about 10 minutes
Jun 09, 2010 | Whirlpool LER4634J Electric Dryer
Drum squeaking noise
Jun 08, 2010 | Whirlpool GEX9868J Electric Dryer
Dryer is noisy especiallly after start up.
Jun 01, 2010 | Whirlpool LEQ9030P Dryer
Dryer squeaks for a few minutues when you first turn in on and then everything is fine
It could be one or more of the items listed below.
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing assembly does not fail often in this type of dryer. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there. All parts come with installation instructions. Not all models are available.
May 13, 2010 | Amana NDE2330AY Electric Dryer
The dryer is making a rumbling sound when in use. It has some vibration but not like it is out of balance. When you open the door the drum stops immediately. Upon restart it makes a more mechanical sound...
May 03, 2010 | Maytag Dryers
The Model is actually 110 63032101. It is vibrating badly. The rollers seem ok. The idler pulley may be bad. I am not sure if the belt is loose
Apr 13, 2010 | Kenmore 62602 Electric Dryer
I need to replace color wheel in my Rca dlp television
Color wheel is available on the internet for this model--for less then RCA sells it for:
http://www.betterlamps.com/comersus/store/comersus_viewItem.asp?idProduct=138
Use this link to view it----it is 199.00 plus shipping etc.
If this has helped you---I DO THIS HERE FOR FREE- take a minute and give me a vote here.
If you have more questions or need advice--reply to this posting here.
The site shows the part number for this part and which models it is used in.
REGARDS, SD TECH
Sep 12, 2009 | Televison & Video
Whirlpool WGD7800X Cabrio Steam 7.6 cu. ft. Gas Dryer Logo
51 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
