Question about Sony MHC-GX450 CD Shelf System
CD changer major problem
This is really hard to describe, but one day when ejecting the cd changer, it turned all weird. The changer keeps changing cds, making weird noises. I open it, and it tries to spin to show me the cds, but has trouble, and i can here the motor running but no turning unless i give it a push spin. After that, it doesn't close, and its all weird, it constantly tries to spin after taking the plug out and putting it back in. It seems like maybe something is off the track in the cd changer. Any ideas on how to fix it? Is it recommended that I open it up and give it a try?
    Novelist:
    Champion:
  • 219 Answers
You probably have a small plastic gear stripped out or a belt slipping and it will need to be replaced. I wouldn't recomend a do it your self repair. This is most likely a job for a professional.
Posted on May 23, 2007
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
When i change from radio or single disc to the 6 disc changer there is an error it won't read any discs.... It wont even change discs it won't do anything really...
I suspect that your 6 cd changer is having the fault. The error indicates always a system malfunctioning. From our point of view we can probe into for a solution by the following guidelines.
first of all open the 6 Cd changer from the top. look within to find that the changer is jammed inside. If so slowly tapp while you switch on the power. if the jamm clears and the changer ejects, then open out all the cd's present in the changer for any damage due to heat. If this did not solve, clowing chek for foreign particles/dust that has blocked the loading drive.from completing the cycle so as to reset the mode. normally all errors show because of the processor not receiving the complete cycle signals. hence check for all the moving parts, the drives and the loading mechanism. check also for any linkage damge, any leadd specially flexible line wiring to the motors for an open circuit. Slowly turn the motor drive to intiate to confirm if the motor has failed. Altogether use a multimeter and check in all the sections described.
I hope this helps. Good day.
Jun 28, 2010 | Car Audio & Video
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
Cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Feb 09, 2010 | Alpine CHM-S630 6-Disc CD Changer
2001 Lincoln LS: CD Changer wont eject CD's. Keeps saying CD ERROR when I press eject then select any of the 6 CDs. Also, it says slots full when I press load and press any of the 6 CDs. I just bought the...
you really need to take the cd changer out of the dash,and then open the cd changer ,is one of you cds is making the problem,ones is remove it should be working fine,good luck
Sep 17, 2009 | 2001 Lincoln LS
CDC-3 magazine will not eject nor play, error on receiver indicates magazine error
1998 porchea boxter cdc-3 cd changer, The cd changer keeps on changing tracks as if their are no cd's in the changer. keeps going from 1 to 6 and then changes to radio.
May 19, 2009 | Becker Car Audio & Video
Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Mar 22, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Wont play and keep ejecting
Make sure there is power to fm modulator. There are 2 reset buttons, one on controller and one inside the door of the changer, push both.
Nov 23, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
6 disk cd changer in 2002 Ford Explorer V8 AWD
I have a 2002 Ford explorer and a 6 disc cd changer, all slots are full, no CD's will eject or play. I just took my car to a local body shop, they went under the hood, disconnected my battery, plugged it back up and my CD's came out when I pushed the eject button
Nov 06, 2008 | Car Audio & Video
Changer refuses to eject or play CDs, keeps saying reset
Hello, in order to repair CD changer you have to be equiped with special tools and knowledge. This repair is only possibble in Authorized Sony Service or at the shop with best references for this kind of job. Best regards, Arpi
Apr 13, 2007 | Sony CDX-656 10-Disc CD Changer
Sony MHC-GX450 CD Shelf System Logo
245 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
