Question about Microsoft Windows XP Home Edition
Keep crashing had window Xp for 3 years running well, now it is keep crashing after using it for about an hour, it just says system shutting down
  • 189 Answers
Maybe your computer was infected by virus, if the cd installer is still with your have it re-install back-up your important files copy it to a dvd or cd before it become worse were all your important files will be lost.
Posted on Jan 06, 2009
I have a IBM Think pad laptop running Windows xp that keep shutting down, it go through the POST OK. then 2-3 minutes it shut down. The fan is OK, and the cooling system is ok, so what do I do next.
Hi
its either a software problem or a hardware problem
normally over heating shuts down older style laptops
try using a lap top cooling pad
sometimes its a faulty hard drive
Try reinstalling XP windows again
cheers
May 21, 2015 | IBM Computers & Internet
My Toshiba Satellite L305-S5875 always crashes on a cold boot.
Part of the problem is the hybernate function it causes windows to become unstable and eventually will corrupt the windows files making vista unusuable. I strongly suggest the hybernate mode be disabled and you make a backup recovery disc just in case windows crashes. By following what I have recommended and shut down windows when not in use will make a big difference in stability.
Apr 22, 2012 | Toshiba Satellite L305-S5875 Notebook
My sony vaio VGN-B1XP, running windows XP, keeps shutting down. It is now 5 years old?
hi
thank you for using Fixya
if your windows shutting down in startup then you have problem with windows only
if your windows runing till your desktop then it's shutting down it meance u have virus in your pc
May 14, 2010 | Sony Computers & Internet
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
Possibilities:
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
Dell Inspiron 1525 shuts down
You have had Win 7 for TWO YEARS? Hmmmm well anyway thats the problem. You see Win 7 and games don't MIX, the only way may help is to run in compatibility mode for XP SP2, and Run & Install as Administrator.
Mar 19, 2010 | Dell Inspiron 1525 Laptop
Blue screen in xp & system shuts down
Friend,
It is an indication that Windows is about to crash. You must do the following immediately:
1. Back up all your data if possible to a different drive. Or at least out of C:\Windows folder where MY Computer resides.
2. Go to www.ccleaner.com. And download CCleaner, the registry cleaner. What happens is that all programs registry themselves with Windows Registry. When yo uninstall the some do remove their traces from the registry, most do not. And the registry keeps bloating. This not only slows down the PC but also can cause a crash when a lot of junk is there. So use this CCleaner and remove all the junk from the registry. And you may not have to reinstall Windows. And if you have to then you have to and are prepared for it by having taken a backup of your data.
Dec 19, 2009 | Microsoft Windows XP Professional
Same as above I think
first of all never never never use hibernate only use standby. you want you hard drive to crash and loose all you info keep hibernating your laptop.
Jun 22, 2009 | ASUS Eee PC 901 XP Notebook
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
My Desktop Computer won't start up.
Mine has crashed. So has yours. It has crashed. You must try to boot it with a boot disc made for the operating system. As its 8 years old the manufacturer wont sell you a boot disk but you can buy a boot disk for the correct version ofwindows
Mar 10, 2009 | Sony Computers & Internet
Microsoft Windows XP Home Edition Logo
101 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
