Question about Water Heaters
IDEAL COMBI HE24 ISAR WHAT DOES D MEAN
COMBI BOILER
5 Suggested Answers
  • 234 Answers
SOURCE: I need an Instuction manual free to download for
http://www.screwfix.com/talk/thread.jspa?forumID=25&threadID=27577&messageID=268842
I hope this help you.
Posted on Mar 19, 2009
  • 150 Answers
SOURCE: combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Posted on May 03, 2009
  • 54 Answers
SOURCE: combi boiler hot water far to hot.
Yes the temp can be adjusted, the dial is behind the cover. Turn off power before removing cover.
Posted on Sep 14, 2009
mrhotandcold
  • 248 Answers
SOURCE: hi, my ideal combi boiler mini HE C24 has lights
could be your microswitch check overheat stat and fan are o.k. best of luck
Posted on Oct 21, 2009
My ideal logic combi 30+ is saying ignition lockout and my radiatiors arent heating up as well as my water not turning hot. How can i fix this please?
Lockout is a safety feature. Usually a latching condition and needs to be investigated rather than blindly reset. (The Combi has a bit more intelligence.) With the ignition locked out, you can't hi-fire the boiler, so no hot water of either type. The 'L' should also show a code number - check your user manual (google) for more guidance.
I've had a lockout on a non-combi: it was caused by lack of circulation of central heating water through the boiler.... The system boiled and the trip tripped. The pump WAS running, but wear in a valve actuator resulted in the valve feedback saying valve open while it was physically shut.
Dec 31, 2016 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
My potterton boiler ignites itself after turning it on then goes out
Assuming this is a combi boiler and you mean that the main gas burner comes on then off:-
How long after - 5-20 secs check overheat thermostat Check the wires to it are firmly in place i.e. making a connection. If Ok? then you can short this out by joining the wires together - do with boiler OFF at mains electricity
Longer - say 1-2 mins check secondary heat exchanger for blockage - usually furred up inside & only solution is replacement
Dec 22, 2009 | Water Heaters
Combi boiler hot water far to hot.
Sep 11, 2009 | Water Heaters
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
Combi boiler problem
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
Water Heaters Logo
56 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
