Printers
Problem for Printers
Generic problem for all Printers
Printer worked fine until yesterday.
By jpjaxx731 on Jan 05, 2009
Printer worked fine until yesterday. I replaced my black ink 56 cartridge on my hp 1350 all in one printer. reconected printer and the test page printed, I also was able to make copies, with no problem. My problem is that when I tried to print something from my computer, (Windows xp) It does not print anything. Please help me with this problem and get my printer to work, Thanks
Solution #1
posted on Jan 05, 2009
Somewhat Helpful)
dantechcom
Rank: Guru
Rating: 89%, 719 votes
Take the cartridges out and reset them make sure they are secure. Print the test and alignment page and use it to align the cartridge.
I hope this will help you. Drop me a comment if you still have problems. I will help you.Your vote is highly be appreciated
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
rockfixya
Rank: Wiz
Rating: 80%, 343 votes
check the cable connected to pc.
Comments:
Jan 05, 2009
- i think might be you missplace the cable connected to pc or there is any pin in the cable is broken.
Thanks for using FixYa
Jan 05, 2009
- let me know the solution works for u or not.
Jan 07, 2009
- Thanks for using FixYa.
Was this helpful?
Yes
No
Solution #3
Not Helpful)
fer_nan_14
Rank: Guru
Rating: 86%, 43 votes
hi try to use system restore
Was this helpful?
Yes
No
Solution #4
Not Rated)
jack_daniels
Rank: Wiz
Rating: 81%, 86 votes
download the printer driver HERE and install it to your computer
Was this helpful?
Yes
No
Solution #5
Not Rated)
bestdarngood
Rank: Guru
Rating: 89%, 446 votes
hi jpjaxx731
Check your printer queue. It probably has something in it. Cancel all print jobs, and then try printing something. You can do this by going into the Printers and Faxes and right clicking on your printer and clicking on cancel print jobs.
If this doesn't work, try to restart the computer and printer. If that fails, then uninstall the printer and reinstall it. If that doesn't work, let me know.
bestdarngood
Was this helpful?
Yes
No
Solution #6
Not Rated)
robshow
Rank: Wiz
Rating: 81%, 122 votes
Check to make sure the printer is set as default, In control panel then click on printers. If it is not set as default right click the printer icon and click set as default.
Was this helpful?
Yes
No
Solution #7
Not Rated)
mrrightt
Rank: Master
Rating: 70%, 48 votes
its the problem of connection between the printer and the pc.just check out whether the usb wire is connected properly. aslso reinstall the drivers and check out.
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not... (More)
Answer
I need to make my existing Canon 2400 up and running. The existing external controller is burned... (More)
Answer
When I try to open the HP Solution Center I get the error message: Parsing error in file c:\Program... (More)
Answer
need disc won't print and can't find the original disc to install
Answer
getting white streaks on black and color horizontally. km bizhub c352p mostly on screens, somewhat... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
