Question about Home
Descale mira sprint
When turned off the water still drips from the shower body when hose is removed, i presume this means it may need a descale HOW
  • 171 Answers
SOURCE: mira cold feed only power shower
Hi davecross,
I'm Harvey, the Master Plumber.
Your question is:
water pressure not great would a external pump help. Depends on your situation. If you live in a house with a well pump then turn up the pressure. If you have city water and the pressure is lacking then either install a house pump after the meter or if it is just the shower you're worried about then a booster pump on the shower line is the ticket. Be aware that useing the booster may reduce the pressure at the other faucets in the house while it's being used. The house pump will not exhibit this. You will likely need a local pro to help you with installation. Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you, Harvey, your Master Plumber
Posted on Sep 10, 2008
  • 8 Answers
SOURCE: Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Posted on Jan 08, 2009
  • 34 Answers
SOURCE: shower goes cold after 5 mins
Sounds like you have got some elements out in the unit or you need to turn the heat up.
Posted on Feb 05, 2009
  • 34 Answers
SOURCE: does not stay hot long goes cold after 5 mins in my mira shower
This sounds like the elements or you just may need to turn the heat up. If it under two years old call the manu on the warranty. They make a good product so they should help you. I would check the heat setting first, though I doubt it is going to be the prob.
SOURCE: My Mira Advance shower is constantly dripping when
Think you will find its the flow valve inside the shower is not shutting correctly so letting by some water.
Posted on Jan 04, 2010
My mira elite 2 shower is leaking,The flow and tempt is ok. but the leak has got worse and it is cold water the leak is not from the hose that is connected to the shower head. It only leak when its on
Please use plumbers white tape wrapped in a clockwise diection. Tighten and let us know Geraldine. Thank you and send us a picture if you can. Best of luck leave feedback
Jul 13, 2016 | Home
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
Descale a showerhead
  1. What to do
    1. Unscrew the head of the shower from the hose. This may be quite stiff. ...
    2. If it is possible, unscrew the rose attachment from the shower head. ...
    3. Soak the parts in the descaling agent or white vinegar overnight. ...
    4. Reassemble the parts, checking that the rubber washer for the hose is in place.
Descaling shower head
Jul 21, 2015 | Water Water Heaters
Mira shower manuals
If you have water with head removed, Remove and soak shower head overnight in vinegar to remove hard water deposits.
Jun 09, 2014 | Home
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
Mira go water shower is not delivering water
IF LITTLE WATER DRIPPING FROM SHOWER HEAD SHOWER HEAD STOPPED UP BUT MAKE SURE WATER FLOW OUT OF TUB FAUCET GOOD STRONG IF NOT YOUR WATER PRESSURE TOO LOW.
Oct 15, 2011 | Home
My mira sport shower when switched on runs afew seconds and stops, then when switched off runs afew seconds then goes off. pls can someone advise. thank you
detach the hose from the shower head and clean the filter screen and do the same with the shower head. When you have the shower head detached turn the water on to the shower and see if anything comes out into a towel or bucket.
Feb 15, 2011 | American Standard 1660.501 Sport Hand...
Mira thermostatic shower water dripping from bottom of casing
Switch off the power supply to the shower at the consumer unit, it will probably have its own individual circuit breaker as it is such a heavy user of power. Try now to switch the shower, it should be dead and that is good. Remove the control knobs and remove the front of the shower unit. Check the electrics with an electrical screw driver to make sure that there is nothing that will cause electrocution. Trace the source of the leak, the most likely place is the compression joint to the mains water pipe. Tighten the compression nut until the dripping stops. Dry everything off with a paper towel and check there is no sign of further leaking. Reassemble the front with the knobs and switch the power back on.
May 27, 2010 | Home
Every time we use the shower there is a very pugnent smell [fishy] all drains been checked, all pluming been checked, all water is fine. shower is 11 years old could this be the problem. the shower we have...
Also check the following things:
The control unit, hose and shower head - depending on the type, some heads will hold water. Remove them and check to see if they are exhibiting signs of mold or possible failure. At 11 years old, the element could be on its way out. If your Mira unit has an auxiliary pump, it should be checked as well. If it's the shower head, you can try to soak it in white vinegar to remove the smell, or simply replace it. If you have well water, you should consider flushing the system to be sure water isn't being trapped somewhere. Also, if the iron content of the water is high, or if your water softener isn't operating properly, that could be an issue as well. The Mira control unit may need to be de-scaled or otherwise checked.
Check the shower stall walls (with no tub) at the bottom where they meet the basin, unless the shower enclosure is all one piece. There could be mold behind the intersection of the walls and base.
Look for any trace of mold growth around any other enclosure components.
If the shower is in a tub, remove the overflow cover on the tub and see if there is any trace of mildew or mold in that area. Follow your nose.
Finally, check for any excessive build up of soap scum, although this is less likely because you'd notice it more readily.
Things like this can be tough to diagnose, so just take things slow and one at a time.
Mar 08, 2010 | Home
My Mira Advance shower is constantly dripping when in the off position. This is getting progressively worse, does anybody know whether this will be an easy repair.
Oct 28, 2009 | Home
Home Logo
35 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
