It wont heat the inside of the jeep,the jeep has no other problems.
Something similar happened in my Jeep last winter...except mine was only the driver's side. The passenger side blew hot air when heater was on, but the driver's side blew cold air. The solution for me was to replace something called the 'blend air door'. It fixed the problem but cost me nearly $500.00. Hope this helps...
Hi I have a 2002 JGC ltd and it is most likely your dampeners or louvers located behind your temp controls (inside the dash) for driver and passenger sides that control the direction of air flow from air outside in, circulation, heat to windshield, centre and or to floor etc. I had a friend that had heat only to the passenger side and cold air blowing to driver side. He took it in and they replaced stuck dampeners and it was not cheap. Sounds like the tipical problem with heaters.
