The screen of my player is really dark and i am barely able to see anything. I checked the brightness level and it is all the way up, and it did not help. Is there any way i can make the screen brighter and visible?
Did the screen come that dark, or did it go dark recently? Backlight may have burned up, panel may be bad. Had a similar occurance with a Creative Zen- can't fix these things. All you can really do is return it.
You tried setting the Brightness to maximum, but the screen remained dark? Could be a problem with the LEDs that light up the screen. Also try turning it off and back on.
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
there are no more details
