I have freejet printer 320 plus wuth epson head it's working but doesn't print any thing at all ... what i have to do
sharksupport
  • 14 Answers
SOURCE: Epson stylus photo 810 won't print
Is it just not printing on the paper and feeding it thru, or will it just not do anything? I need more info?
Posted on Dec 05, 2007
the terrier
  • 94 Answers
SOURCE: EPSON LX300+ prints garbage
hi print out
reinstall the printer driver this should reload the correct printer code page
Posted on Oct 30, 2008
aicaxz
  • 511 Answers
SOURCE: Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Posted on Jun 10, 2009
SOURCE: epson r290 printer no printing now
how to install and R290 printer & print
Posted on Jun 13, 2009
pineworks
  • 4041 Answers
SOURCE: Hi help needed with a Epson stylus Photo
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 25, 2010
Testimonial: "thanks for the help, i've cleaned the head but cannot get the print head to srart printing. "
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
Epson workforce 545 is printing & coping blank
Jan 18, 2013 | Office Equipment & Supplies
Epson SX110 printer does not print
I assume from your description that the printer is going through the motions of printing but not putting ink from one or more colours to paper. If this is the case please it is likely that the printhead has developed a slight blockage or ceased to function.
-Print a nozzle check from your printers software. This will show you clearly which colours are not printing correctly.
-Run 1-3 head cleans using the printers software with a nozzle check after each one.
-If this doesn't resolve the issue it is possible you simply have a defective cartridge and I would recommend replacing it and trying again.
-If this doesn't help or the problem is across all colours it is likely the printhead is severely dried or has reached the end of its life. So I would either take it to an Epson service center or if the printer is not worth the expense you just keep running head cleans (with 5-10 minute gaps between cleans).
Hope this helps.
Sep 08, 2012 | Epson Office Equipment & Supplies
Epson Stylus Photo R800 not printing certain color
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 15, 2012 | Epson Stylus Photo R800 InkJet Printer
INK PAD FOR MY EPSON ME320
where i can find the reset button of epson me 320 printer?
Jan 10, 2012 | Epson Office Equipment & Supplies
I changed black ink cartridge and now pages that are printed are really poor quality and really hard to see...faded in color and sometimes smeared in some spots. Help.
Try going into the menu and cleaning your print heads. If that doesn't work, take out the cartridge and using a cotton swab and alcohol, clean the print heads.
Aug 16, 2011 | Epson Stylus 880 InkJet Color Printer
PRINTER DOESN'T PRINT
Firstly you need to clean your printer head clean with Amonia. Wash gentaly soft hot water. Then inject some amonia solution ( amonia+water30%) Smothly. Then reasemble your printer head.I think your printer remain work again.
If not, the problem is in your printer main board. Replace it, or repair the main board by the expart tecnishian.
Thank you.
May 19, 2011 | Epson Office Equipment & Supplies
Photos are printing with too much blue un them. I have changed the color cartridge, cleaned print heads, etc. I am using only Epson namebrand products. Is there any adjustments I can make to correct this?...
It sounds like the print head may be clogged. To clean print head:
  1. Get a saucer and fill it with hot water
  2. Dip the print head in for 30 minutes
  3. Wipe the print head with a dry cloth
  4. Repeat the above at least 3-4 times (replace the hot water in the saucer each time)
  5. After repeating and wiping down the print head, put it back in your printer, put the cartridges in and run the print head cleaning function 2-3 times.
If it still doesn't work, then you may have to replace the print head.
May 10, 2011 | Epson Stylus Photo R280 Series
Epson stylus photo r300 removed print head, flushed out all nozzels with water, dried everything, reasembled everything, including the flat ribbons, two different times. After dozens of times trying to...
If an inkjet printer has not been used for some time and several print head cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 24, 2011 | Epson Stylus Photo R300 InkJet Printer
k24674
jasbo
jasbo
