Question about Kenmore 24 in. 15932 Built-in Dishwasher
Will not drain
Mod# 665.16369300 Type: 575D Ser.# FP4909003
will not drain. took out all of the plastic pieces in order to gain access to the pump, found that pump spins freely. took control assembly apart and held door safety switch closed to observe operation. fresh water inters tank, pump comes on and runs through cycle.(ran in quick rinse) pressure seems to be adequate, hard to tell though with plastic piping removed. cycle will run approx. 10 mins. then nothing. pressed the Cancel/drain button, and nothing.
Hope to hear back soon, Wife says i have to wash dishes by hand till i get this fixed.
Thanks in advance.
Steven Vanover 903-387-0011
Winter Haven Florida
  • 8 more comments
  • sirvan69 Jan 05, 2009
    I believed if i gave the model numbers i would get a less "Generic" answer.
    when the "drain Cycle" is on or selected there is absolutely no sign of anything running. the drain line is clear and free of any obstructions
    is it possible to obtain prints on this assembly? ive removed the screws that hold down what im considering the pump assembly cover, but cant seem to get the cover off?
    ive checked the drain line for obstructions, there are none, there isnt a checkvalve anywhere inline.
    the pump spins freely by hand and seems to operate just fine in the "wash cycle" doesnt seem to be getting a signal to drain
    there is NOTHING in the drain line
    im pretty sure its an electrical problem. Does anyone here have knowledge of where i need to start specific to this model?
    when i said it runs 10mins that is the length of time the owners manual claims for it to run in the "quik rinse" mode it does this just fine, and to answer your question, it does circulate the water. i was trying to gain access to the impellers through the inside of the machine. pulled the screws that hold what im thinking is the pump/impeller. can seem to get it off without breaking something
    i think i might of found something here guys!
    found what looks like the blade of a food processor, wonder if it work with out it?
    Genius:
  • 2,120 Answers
Check the black rubber FLAPPER in the pump discharge neck, they break off and plug up outlet.
Posted on Jan 05, 2009
  • 1 more comment
  • Leroy Elliott
    Leroy Elliott Jan 06, 2009
    No. nope, nyet, nada, it's solution #2
  • Leroy Elliott
  • Leroy Elliott
    Leroy Elliott Jan 07, 2009
    It's the rubber flapper.
    Novelist:
  • 148 Answers
It sounds like your drain hose is clogged under sink
FIX
1 open doors under sink
2 put a bucket under disposal and turn power off at breaker for dishwasher and disosal
3 remove hose clamp that attaches drain hose that is attached to disposal with phillips or flat head screw driver
4 pull hose off off and dump debris into bucket
5 try to get any debris out of the drain ose and check opening in disposal for any debris
6 re attach hose and turn on power
Good Luck
  • 163 Answers
I know what call this guy
  • Kenmore Master
  • 19,396 Answers
If drain pump works, and drains at the right time in the cycle, then it is a blocked drain line, if there is no power to drain pump during cycle, then it is a wiring problem or a bad control board. Testing voltage is not an user level operation for obvious safety reasons.
    Master:
  • 416 Answers
Dishwasher can not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
Good Luck
  • 3,037 Answers
Hi Steven
sorry to here that you have to do the dishes
If you don't see any stuff stuck in the upper impeller, then you may have a bad motor. A new pump/motor assembly is pretty costly, you can check your owners guide, some brands give you a 5 yr. part only warranty on that pump/motor module assembly. You may be just right at the end of that 5 yrs so check soon.
You said it spun freely, but does that mean by hand or by electricity?
To get the motor out please visit the following link
http://www.applianceaid.com/dishrepairhelp.html
bestdarngood
    Sergeant:
  • 367 Answers
Where the hose connects under the dishwasher is a check valve... remove the hose then unscrew the large white check valve... most likely clogger the center is only about 1/4" hole. Also if you installed a new garbage disposal make sure the knock out hole is punched out.
    Sergeant:
    Scholar:
  • 199 Answers
f the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
  • 679 Answers
Might be air is block the drain pipe way.
Thanks for using FixYa
  • rockfixya
    rockfixya Jan 06, 2009
    so, they help u to solve problem.
  • rockfixya
    rockfixya Jan 07, 2009
    Thanks for using FixYa.
  • 530 Answers
Ok, do you have a volt meter? when you put the unit into drain do you hear any humming sounds? locate the pump and see if you are getting 120 volts?
  • 6 more comments
  • erica graber Jan 05, 2009
    If you have 120 volts getting to the pump you know that this is your problem
    Hi Steven,
    Also make sure that you are not looseing your voltage. It may be a problem in your wall. If the unit is not hard wired in try running it to another wall socket. You say that the unit is running for 10 minutes so does that mean that it is recurculating the water inside? Do you have a machanical Timer or electronic? If it is a machanical timer does the timer stop then advance to a point then stop?
    Also, just curious is there power at all now? If not it is a possible blown fuse inside the control panel. there are torque screws that you have to remove to access the control. But you knew that. so attached to the controller is a fuse with 2 wires going to it. Take it off and check for continuity. If there isn't any you need a new fuse.
    Hello, Steven pull dishwasher out. You have a recurculation pump which recurculates the water. You also have a drain pump that is attached to the side of this recurculation pump.I believe it has a blue wire and a grey wire going to it. YOu can access this by pulling the dishwasher out and looking through the right side. pull the insulation out of your way. Check the voltage going to the pump make sure you have 120v if you do not the problem is not your pump. It would be more than likly your control board. Please check the voltage and get back to me
    Ok since the recurculation pump is working fine that piece that you just found is called your chopper and NOOOOOO it will not work without it. Now you have just created a problem. It will no longer recirculate the water to the top rack or clean out your detergent. PLEASE reattach the chopper and close that area up you are in the WRONG area.
    I would say since you have no sound comeing from the pump it must not be getting any voltage. sounds like you have a problem with either your one of your door switches or your control board
    I would turn the power off to the dishwasher by either unplugging it or turning the fuse off a t the curcuit box. Locate the DRAIN PUMP. follow the wire from the drain pump to control board make sure there aren't any breaks in the line. sometimes mice can get into there and do some serious damage if you find broken wires I would say the dishwasher is done for.
    But if not. could be 4 things DRAIN PUMP, DOOR SWITCHES, CURCUIT BOARD, or you have something going on with your HOUSE WIREING
  • erica graber Jan 06, 2009
    please let me know if this is helpful or a fix
    Thanks egraber
    Genius:
  • 3,422 Answers
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Belt
Motor
Timer
How do I get to pump on EIFLS55IIW0 Electrolux front load washer
Hey friend, thank you for your post!
Based off the information you have provided I see you want to access your drain pump. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your washer to gain access to your drain pump. Hopefully this is helpful. -Matt
Sep 29, 2014 | Electrolux Washing Machines
Dishwasher leaking from bottom of dishwasher. Maytag Portable Dishwasher MOD MDC4650AWWO SER NW4610106
Hi
The issue is with the water not draining as something might be blocking the drain pump assembly thus the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that is fine. Hope this helps...please post back for further assistance.
Daniel
Jun 28, 2011 | Dishwashers
Not draining an erro comes up E20 on it
E20 = draining issue. The most common problem is a blockage at the drain pump.
This can be checked by a DIYer with general hand-tools.
1st. Unplug the washer! We don't want to get shocked.
2nd. There is a lower panel on this unit which can be removed by removing two screws at the bottom. Remove this panel to gain access to the drain pump area.
3rd. Find a big diameter black hose coming from the bottom of the wash tub and follow it until it gets to a plastic housing with an electric motor sticking out the side. (there will be a smaller diameter hose coming out of this plastic housing as well this is your drain hose)
4th. Remove hose clamp on large black hose and remove hose from pump (water will flow! be ready)
5th. Check hose and pump for blockages... One of the most common is under-wires from the wife's bras. Spin impeller of pump to insure that it moves freely.
6th. Put it back together in reverse order of taking it apart. Try unit out by starting a cycle without clothes. Then put it in a spin cycle to see if water drains.
May 17, 2011 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Affinity E20 code without washer draining?
Plug off the mains. You have to look for screws below the front kick-panel, you can raise the machine a bit to gain access to the screws, the panel comes down & out. You may find a drain hose here, on left, drain off the excess water. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. You can pass it into a large plastic bag. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
You can give me a very helpful rating for the free help, can't you. Thanks.
Jun 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a Whirlpool washer, Serial #CL1510429, mOD #LXR7133JQ1, Type 107. The washer stops right after washing. Water will not drain nor will it spin. What is the problem?
3949247 - LID SWITCH *** is probably bad. these units only look for that lid switch circuit to be closed at the end of the wash cycle and end of the rinse cycle, prior to spin/pump out. its a safety switch so the unit shuts off when you open the top.
you can go to several sites and find parts blow ups so you can find how to access that switch thats below the top.. hint: the top, front, and both sides come off as a unit to gain access to the components below, leaving the chassis sitting upon the floor.
best of luck,
ttfn
Oct 24, 2009 | Whirlpool Washing Machines
Kenmore washer odor
The most likely cause of a burnt rubber smell is a worn motor coupler.
Sears parts site
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24922200&pop=flush
Go to the sub section with the brake/clutch/motor/gearcase and item # 13 is the motor coupler between the motor and transmission.
It has three parts. 1. A plastic piece with three prongs fits on the transmission input shaft. 2. A plastic piece with three prongs fits on the motor output shaft and 2. a RUBBER grommet with 6 holes fits between them.
Over time, the rubber piece can wear and the two plastic pieces can rub against it at speed causing a rubber burning smell.
Replacing one is easy.
Remove the cabinet, the pump (2 clips) the motor (two screws and clips) and the motor mounting bracket (two 1/2: bolts).
Remove the rubber piece and pry off the two plastic pieces. Fit the new plastic pieces on the transmission and motor shafts. Replace the mounting plate. Carefully line up the six holes as you put the motor back on.
Replace the motor mounting clips, the pump and clips and cabinet.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Cleaning my washing machine. Fluff left on washed clothes.
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
http://media.fotki.com/1_p,wktwwdgrkbbfrdgxgtqsskgwtqkq,vi/kstdgfskbxktqtggsqb/1/1303472/5961857/image64920img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 31, 2009 | Washing Machines
Maytag MAH2400A Will not drain
You may need to remove the screws holding the top and slide is back a hair to get to thos screws holding the control panel.
Jan 02, 2009 | Maytag MAH2400A Front Load Washer
My LG TROMM (WM1812CW) does not pump out water. I hear and feel the pump doing something, but water does not come out. Then the OE code pops up. I've cleaned the hose and filter. Nada.
This code means that something is blocking either the water drain pipe, pump filter or the pump itself. I had the same problem and removing the filter (as recommended by LG) did not help. It turned out I had a piece of debris stuck in the pump propeller itself and consequently the water would not drain and the wash would not finish, prompting the error. This is what I did to fix the problem.
1. I removed the cover on the left bottom corner and the removed the filter and unhooked the little rubber tube (drain).
2. I removed the pump cover (lower left corner of the washing machine) and unscrewed 3 screws holding the pump from the front.
3. I disconnected the power supply and removed the back panel (attached with 4 screws)
4. Disconnected the two hoses (one black, one gray) from the pump.
5. Disconnected the power supply to the pump (I had to cut a plastic tie holding the connector in place in order to bring the connector closer so I can disconnect it).
6. Removed the pump by pressing a little tab that was holding it from the back.
7. Once I removed the pump from the washing machine, I took three screws out of the pump motor, gaining access to the propeller. This is where I found a little piece of plastic. Apparently propeller couldn't spin because of that obstruction.
8. I put the pump back together and attached the hoses. This is easier to do when you have the pump closer to the back opening of the washing machine.
9. I then connected the pump power supply connector, locked the pump back in its place and replaced the screws.
The total repair took less than 45 minutes. The hardest part was to remove and replace the drain tube springs, because I did not have the right pliers (You need decent size pliers or plenty of strength in your hands to squeeze the metal bands).
The tools you need for this repair are:
a philips and flat screwdrivers, large pliers and a sharp knife (to cut a plastic tie)
May 18, 2008 | LG Washing Machines
Kenmore 24 in. 15932 Built-in Dishwasher Logo
47 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
