Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Fuel Types Can I burn "red" diesel in a L73 heater?
We have the same heater and were told that YES you can run red dye diesel however it can gum up the works and also if the weather gets cold it will gel up!  We were told to run it only in emergency situations and not for very long...
Posted on Feb 25, 2009
  • 57 Answers
Burn only #1 deisel. I'm not sure what red deisel is. I do know the machines are temermental and can gum up easily.
Posted on Jan 05, 2009
How do u convert from kerosene to diesel
there may be possible ways out there to do the conversion but it may put you and your loved ones in jeopardy. kerosene and diesel fuel have different thermal characteristic during the burning process so the heater designed to run on kerosene may not be capable of handling the burning characteristics of diesel fuel.This may lead to unwanted fire incidents and loss of lives. Best is to purchase heater made for diesel fuel.
Oct 21, 2014 | Heating & Cooling
My heater is a reddy heater 165,000btu. when i plug it up it will ignite, it will get a flame for about ten seconds and it shutdown. i recently replaced the ignitor because it broke and replace the fuel...
I would definitely stop burning off road diesel as it is dirty.Remove the top section of the heater and clean the fire eye with windex and a terry cloth rag, and run K1 kerosene it burns so much cleaner. Also make sure that fuel is not an issuecheck fuel filter,fuel lines and don't forget the screen in behind the nozzle.
Dec 14, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Have a ready heater pro 115, never a problem, just wondering if i can burn red die diesel, same as fuel for reefers in trucking, or will this screw it up, thanks Robert
I run put the red diesel into my heater straight from the tank that fills my farm tractors. I have been running it close to 10 years, now. No problems. Smells a bit different. Some folks complain that in extremely cold the diesel gets too thick to flow but I haven't experienced anything of the sort. It might be a localized problem depending on cold weather additives.
Nov 29, 2010 | Heating & Cooling
Grade of fuel required for DESA heater
Dave you can use all three types that you have listed.
The pump is typically set for Number 2/ Diesel Fuel and if you run Kerosene the unit will run a little bit hotter but with a 3E359B you will typically run diesel due to the amount it will use and the increased cost of kerosene over diesel fuel.
Number 1 is similar to kerosene and is the fraction that boils off right after gasoline.
Number 2 is the diesel fuel that trucks and some cars run on, leading to the name "road diesel". It is the same thing as heating oil.
Feb 10, 2010 | Desa International Heating & Cooling
Can you burn diesel fuel
Hi, If this heater is the Reddy 170,000 b.t.u. heater, model # 170t professional series, then yes you can.It is a multi-fuel heater. Fuels it can use are Kerosene, JP8, Jet A fuel, 1&2 Diesel fuel, and 1&2 fuel oil. It must be this model 170T.
Jan 19, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
What is number 1 fuel
#1 fuel is kerosene - this is the correct fuel for the heater
Diesel fuel is #2 fuel and should not be used in these types of heaters
Jan 04, 2010 | Kitchen Appliances - Others
Do i need to replace filter if i have been using kerosene and want to switch to diesel
No, the kerosene is number 1 fuel oil and Diesel is number 2. No.2 is a heavier fuel with more BTU's than the kerosene. After you have burned the diesel for awhile, you may want to change the filter. If you have trouble getting the diesel to burn, mix it with 25% kerosene and it will flow and go through the nozzle easier
Jan 04, 2010 | Reddy Heater 60,000 BTU Kerosene...
Valcun Oil burning heater
usualy oil burners burn #2 fuel oil which is the same as diesel, except for the dye. I knew a guy that burned the oil from a tank in hid diesel truck, worked fine except it was the bottom of the tank and dirty as hell. cost him a couple filters but we were out of barrels lol
Jun 20, 2009 | Heating & Cooling
Mr Heater MH75KT - won't start with diesel
If the MH75KT is the correct model, then it is a Kerosene only heater. Fuels, like oil and diesel all have different ignition points.
See page 3 of the manual.
Feb 03, 2008 | Heating & Cooling
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
155 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
