My Merlin external 1tb portable hard drive stopped working.i think the USB cable may have broken inside the leather casing.Can it be repaired?
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
cheap to fix
  • 404 Answers
SOURCE: external hard drive
bad hard drive, try it on another laptop makesure there's power going to it the usb cable by itself wont work it needs power
please rate
Posted on Mar 05, 2009
SOURCE: female end of USB broken inside external hard drive
try opening it up, screw loose the connection with your usb (the whole component) and then directly plug it into your computer with the plug that goes into harddrive:)
Posted on May 14, 2009
Crankstart
  • 696 Answers
SOURCE: How do I open the case for repair? I do not want to go to a service facility?
Just tore one apart for a data recovery a couple days ago, just a personal recommendation though, These cases are horribly designed, personally I would rather buy a simple case like a nexstar, then remove the drive and move it to the new case.
I'll leave that decision up to you, but you'll see what I mean once you have this one open.
PS, working from memory,
First pry the to halves of the stand apart, it's just snapped together.
Second remove the three screws from the upper half of the stand
Third remove the two tiny screws from the bottom of the main body of the case.
Now, the FUN part, grab 3 wide flat screwdrivers and 3 long screwdrivers(no matter which kind).
Move along the back of the drive(cabling side) prying the two sides apart along the seam. Leave one of the screwdrivers set in the gap to prevent it from snapping shut,
Do the same with both sides
Now you have a choice, if you're taking my recommendation and bought a new enclosure, put on your shoes and at least one glove.... Grab the top, step into the gap in the back and pull hard.
When you hear the satisfying SNAP and stumble backwards it is open.
If you're still planning on fixing the thing, pry up a bit and look past the actual drive you will see three retainers at the front(wedged edge) use the three long screwdrivers to force the center one forward and to pull the to outside ones toward the back(I'm still missing about 3mm of skin on one finger a week later from trying this method). Keep at it till you get the timing right or decide to try it my way ;)
Once you have it open by either method, remove the HDD LED lead at the bottom of the drive from the drive. Pull the drive out and unscrew the on the corner with the USB(under the rubber stopper).
Now you have access and can saulder away at will.
Hope this helps FixYa, lemme know which method you choose and how it goes.
Chris
Posted on May 20, 2009
justin217
  • 85 Answers
SOURCE: Ext. Hard drive no longer recognised by computer operating on XP
Your file system on the drive might be corrupt along with all the data on the drive. You can try to download data recovery software or try the drive on a different computer. I hope this helped solve your problem.
Posted on Jun 22, 2009
My WD elements 1.3 TB external hardisk. It gives a buzz when connected and is not recognised by windows
It sounds like the HDD inside is dead. The USB interface may have an issue but usually clicking or buzzing is HDD failure. If you have a desktop you can try removing the hard drive from the external case and connecting it directly to the computer using a SATA cable.
Jun 19, 2016 | Western Digital Wd Elements Se 1tb...
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
How to recover data from a broken Western Digital My Book Essential
Remove the HDD inside the case,If the HDD inside is working, remove data with a usb to IDE/SATA Adapter. If the HDD is damaged, which is likely, It ,most likely, can be read, but I don't think you are going to like the bill for that service.
Dec 19, 2012 | Western Digital My Book Essential 1TB...
Power socket broken on usb3 1tb verbatim
If you cannot get the connector fixed then you need to remove the hard drive from the adapter case and insert the hard drive into a new adapter case.
Jun 10, 2012 | Computers & Internet
I have Transcend 1TB 25 inch StoreJet H2 USB 20 Portable Hard Drive... not long enough, it's broken; there's a sound "clutch - clutch - clutch"... I cries for my valuable data... Why...
Inside the plastic case of the Transcend StoreJet H2 1TB, is a small circuit board, and a laptop size harddrive.
The small circuit board is an Interface Board.
The harddrive plugs into it, or there are cables which come from the Interface Board, and plug into the harddrive.
The other end of the Interface Board has a USB cable attached to it.
Most of the time it is this small circuit board that fails. Very rarely does the harddrive fail.
(Unless the external harddrive was dropped)
I would suggest removing the harddrive from the Transcend, and putting it into an inexpensive external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Basic guide on how to open the case of the Transcend StoreJet H2 1TB
http://www.youtube.com/watch?v=GvGP6C-rH2U
There are other related videos to the right.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 10, 2011 | Transcend 1TB 25 inch StoreJet H2 USB 20...
About 2 months ago I bought a samsung s2 portable 1Tb. It has worked fine until yesterday. It slipped down from where it was laying (while plugged in and running) and was hanging the 20 cm usb-cabel. Now I...
Hanging by the 20cm USB cable?
The cable could be stretched, and wires broken inside.
The cable to small circuit board, inside the case, could have broken solder joints.
The circuit board inside the Samsung's case could be broken.
Inside that small outer case of the Samsung portable is a laptop size Harddrive.
The harddrive measures 2.5 inches across in width.
(6.4cm. In comparison a desktop size harddrive is 3.5 inches across in width, or 8.9cm)
The harddrive is a SATA unit also.
This is a general example of a 2.5 SATA harddrive,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148591
Inside the outer case (External Enclosure) is also a small circuit board (PCB)
The harddrive plugs into the small circuit board, and the circuit board has a USB cable attached to it.
(Or there is a small cable from circuit board to harddrive. Then a USB cable to the circuit board)
I would suggest removing the 2.5 SATA harddrive, and install it into an economical external enclosure.
Example of a 2.5 SATA External Enclosure,
Basic guidance in removing the Harddrive from a Samsung S2 Portable,
1) It looks as though the outside front is a thick cover like a label. It may be that you peel back the corners, and there will be a screw in each corner.
(For example; Where it states Samsung. Go to the right corner. Does this cover-like material peel back? Is there a screw underneath? Remove it.
Go to the opposite corner. Now above to the left and right corners)
The unit looks to come apart in two halves.
Might just be held together by sticky tape.
Here are some videos performing opening the external enclosure, (Case) of other external portable harddrives,
1) http://www.youtube.com/watch?v=dMzRYCZXVEs&feature=results_video&playnext=1&list=PLC129A4F797CCC09E
2) http://www.youtube.com/watch?v=Y2vUMO2mGLE&feature=related
There are other related videos. In general most are not very professional, but get the job done.
Regards,
joecoolvette
Sep 18, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
Western Digital 1TB My Passport Essential SE USB 3.0 Portable External, WDBACX0010BBKSN USB 2.0 Hard Drive not recognised
Hi there. Here are some solutions you could try 1. Try connecting it with a different USB cable as the present one may be faulty. 2. If you can open the casing, do so to confirm if there is a loose connection. 3. You can try this great application tool from Seagate called Sea Tool. You will need to download and install on your computer. This tool examines you hard drive and lets you know if it is totally damaged. You can download it here. SEATOOL
Sep 06, 2011 | Western Digital 1TB My Passport Essential...
I have 1tb western digital external hard drive. It fell at the usb port got broken, so I went ahead and took it out of it's orginial casing. Placed it in a docking station and all i get is a blinking...
these have software in them for the board in the factory case ...you will have to use a data recovery software to recover contents then reformat the drive OR try installing it as a second drive inside the pc directly to the sata/ide cables not usb. good luck
May 08, 2011 | Western Digital My Book Essential 1TB...
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
David Payne
David Payne
