Question about Honda Garden
How to change oil in my f200 honda tiller - Honda Garden
3 Suggested Answers
  • 5 Answers
SOURCE: how do u change the oil in honda fg110 tiller
The simple way is to take a oil pan and lift the tiller with the plug removed and drain it out while holding over the pan. Dispose of oil properly. I have an older model that does not have an oil drain plug.
Posted on Sep 06, 2010
SOURCE: I have a Honda F200
replace the throttle case by the new one
Posted on Apr 09, 2011
Mantis tiller won't start
Flush out old gas. Check/clean spark plug. Oil filled? Try spraying starter fluid in carb. Carb should not have any oil in it. Change air filter.
Jun 04, 2015 | Mantis Tiller Honda 4 Cycle - No Kickstand...
How do you change the oil on a honda fr 800
-Open oil filler cap or plug at front (Flat Plastic knob) then just till to the front to drain it until no drip then just re fill w/ 10w30 to full level. You're good to go.
Good luck
Mai
Jun 21, 2014 | Honda 25cc 4-cycle Mini Tiller
Pull starter honda f210 rope has come off
remove the starter cover whined the spool in the opposite direction that the rope pulls out hold it into place with a knot on one end feed the other end threw and out threw the opening pull it threw and tie on the pull handle
Aug 18, 2012 | Honda Clutch Cable F200 F210 F260 Tiller
What transmission oil to use for Honda Tiller F501
The tiller manual says to use the same oil as the engine. The table indicates that 10w30 would be a good choice for most temperature ranges.
Sep 24, 2011 | Honda Garden
How do u change the oil in honda fg110 tiller
Aug 29, 2010 | Honda 25cc 4-cycle Mini Tiller
How do you change the oil on a honda fg100
Lay the unit face forward so it is laying on the gas tank and the engine is level. Fill through the dip stick access until oil is up to the bottom lip of the threading.
Mar 12, 2010 | Honda 25cc 4-cycle Mini Tiller
Checked oil level on Honda tiller, Fuel in the oil sum
It's hard to say without personally seeing it, i'd change the oil and see if the problem persists. Note that you should most likely use a synthetic mix if you're unsure of the type of oil used previously. Also when filling these units with oil they should actually lay face down, the gas tank on the ground, with the oil level up to the bottom lip of the access hole. This is a common mistake because most people fill the oil while it's in an upright position.
May 18, 2009 | Honda 25cc 4-cycle Mini Tiller
Where do you drain oil on honda gx25 mantis
jj505 has good and bad information.
Honda GX25 is a 4 stroke motor, with oil lubricated crankcase.
Oil drains out the filler.
Oil and gas do not mix on this four stroke.
The PDF below is the Honda manual.
http://www.smallenginewarehouse.com/images/manuals/GX25-35.pdf
Apr 12, 2009 | Mantis 4-Cycle Tiller
Garden Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
