Question about Acer AL1717 17" LCD Monitor
Shaking the fonts on the screen are jittering / shaking
  • chermal Apr 15, 2009
    DISPLAY IS FLICKERING, AND TWO WHITE LINES ONE HORIZONTAL AND VERTICAL.
    Problem Solver:
  • 6 Answers
On the power supply PCB are two 220uf 25V capacitors that will be leaking. Replace both and the picture will return to normal.
Posted on Oct 28, 2009
    Problem Solver:
  • 5 Answers
Adjust your resolution.you have wrong rsolution
Posted on Jan 05, 2009
Screen shakes or jitters when I touch the screen and try to scroll
It appears to be a Hardware Error. Contact Authorized Service Center or Customer Care if it's in warranty, otherwise call any Smartphone or Tablet Engineer (Hardware).
Mar 29, 2014 | Acer Tablets & eReaders
My car runs at low speed but the car still shaking,Maintain on time, has spent three years Toyota corolla,I want to know what the shaking will what are the reasons?
There are two types of car shake
1, stop idling shaking, this situation is generally low or lack of cylinder engine idle speed. Misfiring need to check the spark plug and the high voltage line! In addition, the nozzle and the solar term door dirty is easy to appear this kind of circumstance! Wash!
2, the driving time jitter, the chassis and a relationship! Because the rod or swing arms open, do a four wheel positioning can be solved!
source: obd2 tool car diagnostic tool
Dec 02, 2013 | Cars & Trucks
My screen jitters
It is not something you can (Repair) Your self. End this sugestion is from a (Technician) With 35 years (Expierance) Under my belt.
Oct 25, 2012 | Sony VAIO VGN-CS220J/W Notebook
Picture shakes
To help you I need to know the set is a 42mf7000 and which direction does it shake or jitter= up/down OR left/right?
Mar 15, 2012 | Televison & Video
When tweaking the motion settings low makes everything jitter really bad and high is a bit better. Even at custom 10/10 it still jitters enough to annoy me. Is it a defective tv? The strange part is...
Try checking the Hz settings on each channel you use. It may be that what you happen to put a setting on is only effective on that channel. Which means if you had to originally set it for 60 or 120hz on the hdmi channel, then you may have to do the same for your tv/satellite channel.
Jan 13, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
Sony hdr-cx7 image jitters when the cam gets hot
one fix is turning off steadyshot then try putting the camcorder upright(the lens pointing up) for few second until you see the video stabilize, then use as normal but the camcorder will jitter again if handle it roughly. This is just a workaround, i still dont know why it happens, need to send it for repair soon.
Jul 22, 2009 | Sony HDR-CX7 Camcorder
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Feb 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Constant jitter on screen
DOWLOAD SOFTWER P5VDC-TVM
Oct 19, 2007 | ASUS P5VDC-MX Motherboard
Akai pdp 4273m 42
I cured the problem by placing a fan in front of the screen that not only blows directly on the LCD screen, but also air underneath the screen providing circulation around the entire unit. Apparently the LCD screen is overheating causing it to "trip". I can stop the blower after about 20 minutes and there is no problem.
I will never buy another Westinghouse product again as long as I live.
Oct 15, 2007 | Televison & Video
Jittering screen
Chassis will need to be pulled by a skilled technician.Some specific area hand-soldering is needed and the STK convergence IC's need changing w/OEM or better quality parts.You have a good set worthy of repair.
Sep 26, 2007 | Toshiba 61H70 61" Rear Projection...
Acer AL1717 17" LCD Monitor Logo
210 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
