Edenpure xl1000 keeps shutting down after three minutes
Heater only works for about three minutes then shuts down. filter is clean.
SOURCE: readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Posted on Jan 23, 2008
SOURCE: heater keeps shutting off !!
I have model 5532, but I think they all have the same problem. There seems to be a safety device in the ceramic heater that turns off if it gets too hot. It "remembers" when this happens as well and will shut off until it is unplugged for 10-15 minutes.
This happens on even lightly used heaters if used in dusty conditions. Dust builds up behind the ceramic heater and the lack of flow causes it to overheat. The unit must be dismantled and the dust brushed/vacuumed out. The good news is that not only will the heater work again, but it will have better airflow too!
To do this, tech support and other people say to "clean the rear grill", but my rear was not dirty. The front grill had some dust that I vacuumed clean, but did not help. In my unit there are no filters before the air goes through the heater element. The problem is in the center of the heater. Taking out the internal fan (four screws on the sides of the squirrel fan box), I could see that the radiator was over half covered in dust. I cleaned that dust out using a shop vac and the problem went away.
Opening the heater was a little tricky, two of the screws were triangle head screws. Once inside, however, it is a simple proceedure to remove the fan. Of course, you should unplug the heater and wait a while before opening it up to make sure there are no electrical charges stored in the unit.
Posted on Apr 05, 2008
tbugger
  • 232 Answers
SOURCE: troubleshooting reddy heater 115,000btu
If a drop of water passes through the system and causes a momentary flameout condition, the photocell tells the control board to shut down- and it does. The photocell has done it's job. The ignitor only gets red for the first 5 seconds of burn-time, then the flame keeps itself going, at least until the water passes. Since water doesn't burn the flame goes out and there is nothing to restart the flame.
Posted on Oct 30, 2008
  • 8 Answers
SOURCE: lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Posted on Feb 23, 2009
  • 188 Answers
SOURCE: Reddy Heater keeps shutting down
I tried to go to www.desatech.com and you cannot buy parts on that site anymore. I can get my Reddy Heater parts at www.masterparts.net.
Posted on Mar 06, 2009
Edenpure xl1000 parts
Replacement bulbs can be gotten from edenpure parts or check EBay for a supplier. Some will ship them no charge. To change them. Remove rear cover, then the cover on the rear of the heater box by 2 screws on the bottom and 1 at the top inside of a "U" Channel. Then lift the rear box cover up off the hanger hooks then back and out. The bulbs will be right in front of you in the 3 holes.
Jan 25, 2013 | EDENPURE USA 1000 Black Portable Heater -...
Duraflame heater runs for 5 mins and shuts off
try cleaning off the filter that is on the bottom in the back of the unit. It is a fail safe sensor that in the event the unot overheats it shuts off the heater. Worked for me on mine.
Oct 06, 2012 | Duraflame Colby Indoor Infrared Quartz...
Need repair manual for eden pure heaters
The Edenpure Gen4 and US-1000 have a set of 3 - 500 watt bulbs that generate the heat. You'll likely need to buy a new set of bulbs every heating season ($60) or pay an Edenpure service center $100-140 to replace them for you. (Almost imossible to get SCI to cover the the bulbs under their so-called warranty)
Unfortunately, despite the hype printed on the box and Suarez Corporation Industries advertising, those bulbs last less than 500 hours of operation in those heaters. Suarez Manufacturing Industries/Pinnacle Systems have no engineering staff nor did they perform any durability testing on the heaters or any heater components.
Thus you, as the consumer, are stuck with continually the bulbs (in the US-1000 and Gen4 at least).
Apr 01, 2012 | Heating & Cooling
Keeps shutting off
You cant clean the HEPA filter.. only the blue washable pre filter.
Sounds like the motor is dead or atleast on its way out.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 28, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Will light and run for about ten minutes then shut down
the home heating fuel will gel thus the heater will shut down
Jan 16, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
