Question about Zenith H25F36DT 25" TV
Locked out of tv
Can not get to menu or remove parental block
Unplugging didn't help. It still says protected program by tv-pg... HELP
Posted on Feb 15, 2009
  • mywel_37 Feb 15, 2009
    Please, help! It's been 6 days now, and i've tried it all.
  • 716 Answers
Maybe Try Unplugging It? Some T.v's Also Have A Reset On Them. If That Doesn't Help Please List The Specific Make And Model.
Posted on Jan 05, 2009
Rca tv stuck on
Locked?
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Gopakumar Gopalan Google
Feb 25, 2014 | Televison & Video
Remove child lock
See the instructions beginning on page 40 of this manual: http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
Jul 17, 2013 | RCA F32650 32" TV
TV power button on my RCA True Flat 27" screen TV
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
Jun 17, 2013 | Televison & Video
No chanels
The TV is locked electronically. To unlock it, you must have its remote control. If you have its remote control,
Lock the controls to activate the changes using item six on the "Parental Controls" menu. If you wish more details abut RCA TV unlock proceedings, check this site.
Jan 23, 2013 | RCA F27665 27" TV
How to unlock childs security?
Instructions
Jun 28, 2012 | Sansui DTV3200 32" TV
My son blocked everyone out of the tv with parental control. He can't remember the password he used and I can't get the reset to do anything. How can I fix this?
If you have reset the TV back to factory settings, you can use the factory unlock code, which is 0000.
To Reset the TV:
  1. Press the MENU button on the remote control to display the Main menu, and select SETUP.
  2. Highlight Reset Default, and press the OK button.
To Remove the Parental Control Block:
  2. Highlight Parental, and press the OK button.
  3. To use the Parental function, must enter a four-digit password. The factory password is 0000.
  4. Select Program Block, and press OK to display the Program Block menu.
  5. You can remove the parental control in this section.
May 25, 2011 | Polaroid TLA-01911C TV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Child lock
  • Step 2 Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
  • Step 3 From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
  • Step 4 From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
  • Step 5 Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
  • Step 6 Lock the controls to activate the changes using item six on the "Parental Controls" menu.
  • Nov 30, 2009 | RCA Mikomi 5290925 15 in. LCD TV
    Fpa lock on how do i get this offf
    hello Lock/Unlock Parental Controls
    Selecting this option lets you lock and unlock parental controls settings
    using a password.
    If you do not lock parental controls, none of the settings for V-Chip,
    Channel Block, or Front Panel Block will take effect.
    If you forget your password, press the MENU button, then select Parental
    Control
    (the password entry screen appears). Simultaneously press and
    hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
    unlock and the Parental Control menu appears. You can enter a new
    password by locking the Parental Controls again.
    Front Panel Block
    Selecting this option lets you block (disable) or unblock (enable) the TV’s
    front panel. The remote still tunes to any channel. When using this as a
    Parental Control method, remove access to any remote that is capable of
    operating the television while you have the front panel blocked.
    Don’t forget to lock parental controls after you change the status. If you
    don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
    shaun
    Sep 19, 2009 | RCA R52WH73 Projection Television
    Can't get the child lock off
    You can use theV-Chip Parent Lock to
    Block or Allow programs based on the
    ratings sent by the broadcast stations.
    The default setting is to allow all programs.
    You can block programs by the
    type of program and by the categories
    you want blocked. Or you can block all
    programs during a specific time period.
    To use the V-Chip Parent lock, you will:
    • Enter a passcode
    • Select theV-chip ratings and categories to block
    • Select theV-chip hours to lock and unlock for television programs
    • Select lock by time
    Enter a Passcode
    MENU
    I. Press _ to display the Main Menu.
    2. PressAorV to select V-Chip Parent Lock.
    PressE_ R,
    3. Using the number keys, enter four numbers. To
    delete a character and move back one space, press
    CANCEL ENTER
    . Press _ to set the passcode and go to
    theV-chip ratings menu.
    MENU
    4. To exit without entering a passcode, press _ to
    HOME
    go to the previous menu or _ to return to
    television viewing.
    IMPORTANT
    If you forget your four-digit passcode, please
    see Appendix 3 : Procedure for Bypassing the
    After you set the lock, you will need the secret code in order to:
    • view a locked program,
    • view the locked TV, or
    • cancel the lock.
    If you forget the code, you can view the locked TV without entering the code. To do this, simply
    press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
    code is requested. Unlocking theTV this way is temporary.
    To change or permanently cancel the lock:
    I. Turn on your TV. If the TV requests your secret code, press
    and_ at the same time.
    MENU
    2. Press _ to view the main menu.
    3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
    4. The on-screen display will ask for your current passcode. Press
    and _ at the same time.
    5. The on-screen display will now ask you to enter a new code:
    MENU HOME
    • To cancel the passcode permanently, press _ or _ .
    • To change to a new passcode, use the number buttons to enter a
    new code, then press E_R,
    IMPORTANT
    You must use the remote control included with this
    TV. You cannot use a remote control from another
    Mitsubishi component and you cannot use "Univer_
    sar' remotes from other manufacturers.
    65
    Nov 24, 2008 | Mitsubishi VS-55707 TV
    Zenith H25F36DT 25" TV Logo
    182 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
