Question about Canon EOS 400D / Rebel XTi Digital Camera
The flash on my Canon EOS 400D won't work
When I try to take a flash photo I hear a repeated click followed by an 05 error code saying 'the built-in flash's auto pop-up was obstructed.' As as I can see, nothing is obstructing it.
Anna
  • 1 more comment
  • egareau Jan 08, 2009
    i have the same problem, and i can pull the fash up manually, but the flash still doesn't go off. is it possible that it can burn out? batteries are full, so i can't think of what else could be wrong.
  • Anonymous Jan 17, 2009
    I have the same problem. It sytated intermintently but is now permanent.
    I was quoted £80 to have it fixed; it is cheaper to but a separate flash
  • roblons Jan 23, 2009
    Hi mine has same problen and I have to pull up manualy (very gently) - think it must be a weakness.
    I did read that sometimes the tiny pin under the hotshoe metal strip , right hand side,sticks down after using a seperate flash. Just ease it back up to cure. Not applicable if you haven't used a seperate flash of course
    Bob
    Sergeant:
  • 367 Answers
Can you pull it up manually, Be careful when doing this but try opening it manually, it is possible that the catch for the flash is just stuck temporarily.
Posted on Jan 05, 2009
When I try to take a flash photo I hear a repeated click followed by an 05 error code saying 'the built-in flash's auto pop-up was obstructed.' As as I can see, nothing is obstructing it. I opened the...
This is a mechanical problem probably due to some sand or such material preventing the smooth opening. Try cleaning the open flash hinges with a cloth or brush. Apply a compressed-air can spray and/or a vacuum cleaner nozzle to the area. This happened to me with the Canon Rebel model. Google for the problem specific to your camera model for other solution.
Please rate Fixya answers.
Apr 26, 2011 | Cameras
My name is Madhu. I use the camera Canon EOS 400D / Digital Rebel XTi. When the inbuilt FLASH is on then a message pop up as "busy now", when i tried to click the camera to take a photo then...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you
Apr 04, 2011 | Canon Rebel XTi / EOS 400D (body only)...
When taking pic an "err 05" (the built in flash was obstructed). On this camera eos Digital Rebel xti 400D. How do fix this?
The obstruction is often caused by the interior latch which refuses to move. If the flash cover ever opens, move the latch back and forward a few times which "sort of" re-engages it to its normal position.
Jul 03, 2010 | Cameras
Cannon error 05
Error 05 means that something mechanically prevents built in flash to pop up. Ensure that nothing is blocking flash. Switch in P mode and press flash button to pop it up. If it does not pop up - try _gently_ to help it to pop up. If you succed in popping up the flash - check it for any dirt with can prevent flash from popping up.
May 29, 2010 | Canon EOS 400D Digital Camera
Flash will not open up error 05
The built in flash's autopop up is not working
Apr 18, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eso err 05 how do I fix it ?
This means a flash problem.
The reasons for it may be several ones. Let me go from the one with higher probability to the lower one.
1. Flash is stuck. It is the most comon reason, and more easiest to confirm. When pressed the shutter (or pressed the flash side button in P mode) you hears a repetetive click noise, and the flash won't pop up. If this happens, the flash is stuck.
Sometimes is solved when at the same time you press the shutter button, with the finger (or nail) you gently pull it up. Once is up, check for dirty, or any residues (such as tape glue, sand or something like that) that stucks the flash.
Some persons apply a thin layer of lubricant on the side hinges. Don't put so much lubricant or oil because will get inside the camera, and cause other problems.
2. If not click sound is heard, the either the flash actuator relay or the DC/DC board (that provides power to the flash board) or the flash board are defective. This can be confirmed only in a camera repair shop.
If you need further support, please let me know.
Best regards,
Jul 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon EOS400D. Every time I try to take a flash photo there is a repeated clicking sound with error message 5 saying, "the built-in flash's auto pop-up was obstructed" yet I don't see anything...
The flash up switch is not working properly. It probably just needs to be disassembled and cleaned. About a $125 repair at most shops.
Hope this helps.
Wes Kauffman
Jan 05, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99 in EOS 400D
Here is a link which may help you.
http://forums.dpreview.com/forums/read.asp?forum=1031&message=9598105
It may be that the contacts on the lens is dirty, follow the directions, by using a clean pencil eraser (I would also suggest to use alcohol and clean the contacts after using the eraser). Also to remove the date button battery and the other batteries, then turn on the camera (with all batteries removed).
Then put the batteries back in.
Jul 23, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
May 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
955 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
