Interface not connected
I have just bought an Epson SX600FW, and the copier and printing side of it works fantastically - I just tried to scan, however, and it says that the interface is not connected - but the USB is connected, otherwise it wouldn't be able to print...so what does this mean? I have two other cables I haven't used to that came in the packaging - one I think is an ethernet, and the other is a telephone cable for the fax part, I think.
Do you know what I could do to overcome this? Thanks a lot!
  • 1 more comment
  • stylusissues Jan 05, 2009
    Problem Solved. Cheers anyway.
  • stylusissues Jan 06, 2009
    Hey, I actually had my neighbour come over to see what he could do, and left him alone - 10 minutes later, the printer wasn't working either. He'd done a good old muck up. Well, I suppose even pc-whizzes can get it wrong sometimes >.>
    I basically uninstalled all the software for it, disconnected it all, and then started from scratch to reinstall the software first and then reconnect the USB cable to it and the computer.
    Hey presto - it worked.
    Must have been a software installation problem.
  • Thomas F. Schneider May 11, 2010
    What was your solution?
    President:
  • 2,692 Answers
Reinstalled software.
Posted on Jan 07, 2009
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
Epson sx215 wont print pdf files
You need to clean the print heads first - if they are blocked they won't print.
Clean them several times - then try the print check.In Case You Still Having Problem Then Follow Us For On : Epson Printer Support
Sep 20, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
I have an Epson Stylus SX600FW I'm trying to print on Vellum but the paper just go through the printer.
use some double sided tape on the edge of the paper it will then grip to that and print the rest of the page you have to trim the end off but its the only way I could get mine to print on velum
Apr 30, 2010 | Epson Stylus CX6000 All-In-One InkJet...
How to clean inkjet of epson styles sx600fw?
Had same problem with my SX600FW. Changed all cartridges umpteen times because head cleaning process empties working cartridges. Ended up with none of the colour cartridges working! Paid Epson repairer £20 for them to tell me the print head was clogged and repair will cost as much as a new printer!! Problem started just after warranty expired!! I shan't be buying Epson again even though it was a great tool when it was working.
Tom
Apr 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Laptop running vista will not print wirelessly
check the cable connections, unplug replug the cable.......then turn it on
Sep 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
INSTALLATION OF EPSON SX600FW
http://support.epson-europe.com/onlineguides/en/sx600series/html_z/p03.htm
this is the web site that explains how to connect to the network. i hope this helps.
please rate good.
Mar 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Connecting wi-fi on Epson SX600FW
I hada the same problem. I used the settings on the actual printer rather than through the software to input the information it needed and It works fine now. I was able to set it up on my husbands laptop without any problems, I just added his laptop through installing the software on his laptops as it had picked up the signal and was showing in the Network and sharing centre on Windows Vista premium. Hope this helps. I think you need to take the wire out now and now load it as wireless. You need to use the wire first to connect then take it out to connect to the wirelss network. My router is a Sky router.
Tiptap
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
974 people viewed this question
jasbo
jasbo
