Question about Acer Aspire 5600 Series 5630-6951 Laptop
Close lid of laptop without shutting down system
I want to close the lid of my laptop without shutting off the computer
  • mdpatters Jan 06, 2009
    Fast and Perfect A++
    Sniper:
  • 78 Answers
You have to configure what laptop do when the lod is closed . go to Control Panel , Power Options , Advanced . In this tab you will see an option " When I close the lid " and a drop down menu just choose do nothing and press ok . It will not shut down your laptop when lid is closed .
If you like my solution do vote for me
Farhan
www.senseapplied.com
Posted on Jan 05, 2009
When I close my lid, pc crashes
Laptop shuts down / crashes after closing lid - used to hibernate ...
en.community.dell.com/support-forums/laptop/f/3518/t/19496556
Dell
Mar 13, 2013 - 16 posts - ‎7 authors
Now shuts down after closing the lid after several hours - at least .... My computer crashes when it goes to sleep regardless of the lid's position. E7440 - sleep Issues and display issues - General ...
Apr 17, 2014
crash after sleep/close lid - General Hardware - Laptop ...
Nov 21, 2012
More results from en.community.dell.com
Laptop Sometimes Crashes When Close Lid to Sleep - Windows
Dec 01, 2015 | ASUS Computers & Internet
I closed the lid without shutting down & now it won't turn on
just whether only the screen lights are off(dim) or actually laptop is shut down.. otherwise remove the battery and then start the computer and after opening search for lid and close and then setting will open and then change "what happens when u close the lid" or make it to do nothing "Change what closing the lid does" - exact search words
Sep 05, 2015 | Computers & Internet
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Dell e5420 close lid power problem
What is the problem? Open Control Panel, Power settings, Advanced power settings, set to High Preformance, Set Sleep and Hibernate to Never , Set Lid close to Shut Down, adjust setting to your preference, Always shut down your Laptop, unplug when not in use. Remove battery if you use on AC most of the time, your laptop will last longer and a boot everyday resets the computer.
Jan 11, 2013 | Dell Latitude E5420 Laptop Computer
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
Notebook Crashes to PowerOff state when lid is closed
Running intense program with the lid closed will cause a sharp rise in temperature making the laptop hotter than it should be leading it into a shutdown. The second issue, windows should be shutdown properly rather than closing the lid, this makes the operational system unstable and will cause files to corrupt eventually.
May 23, 2012 | ASUS N82JQA1 14 HD Notebook Intel Core...
Laptop will not power on. When laptop lid was
System board has failed you will have to replace it.
Feb 23, 2010 | Compaq Presario 700 470024-192 Notebook
Computer re-starts when i want it to shut down or sleep
You should check to see if there is a setting time where the computer installs updates, because the computer may be updating at a certain time and then restarts to finish the update. Check the setting to you might also have the computer restart every so often. hope that this helps.
Jan 08, 2010 | Dell Inspiron 1525 Notebook
I am unable to unhibernate
Power down the computer and power back up. Lets just shut hibernation off...you can always just have the computer sleep...it is much better on the system anyway.
Shutting Down Hibernation
Go to the control panel > Power Options > Hibernation tab > uncheck hibernate…this way you save a lot of disc space and don’t have to go through all the intermittent hibernation problems that occur. After you uncheck hibernation, you can go to the other power options and change how the computer reacts to the lid being closed, when it sleeps and for how long before sleep kicks in. Make sure to change the setting for what happens when lid closes to “do nothing” this will keep the laptop alive even though you close the lid to move it, etc.
Sep 27, 2009 | Compaq Presario 1275 Notebook
TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Computers & Internet
Acer Aspire 5600 Series 5630-6951 Laptop Logo
1,279 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
