Question about Tecnik TKC8525 Double Oven
Bottom oven not working Tecnik 8525/2
My bottom oven isn't working, if I try switching in on it gives a sparking noise and trips the trip switch, the element looks ok, the small top oven is working fine.
Any suggestions very welcome
Thanks
  • Tecnik Master
  • 3,463 Answers
To be certain the element is o/k , you need to test it with a meter.
The fact that it looks o/k proves nothing. If you know how to use a meter, then remove element from oven, and with the meter set on the continuity range, test across the terminals of the heater, if you get fsd, ( full scale deflectoin) then the element should be o/k.
If no deflection , then element is no good.
If in doubt, remove the wires from the element , and try the oven, if it does not trip, then it proves element faulty.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
How or where can I get bottom oven door seal tkc 8525/2 No058587098
Any appliance store should be able the help you with that. Not a big box store. An appliance store.
Nov 13, 2014 | Tecnik TKC8525 Double Oven
Grill on my tecnik tkc8525 tripping out my house electric. Any ideas ?
Probably heating element goes to ground when heating up. Suggest changing element.
Nov 10, 2014 | Tecnik TKC8525 Double Oven
Fuse keeps tripping
tripping a circuit breaker indicates a dead short or insulation failure
not being able to move the main switch indicates that the contacts inside are burnt together
only option is to call an accredited electrician to test the circuits and rectify the fault
tell him to bring spare elements is case on e or both have burnt out
Mar 27, 2017 | New World Ovens
Main oven causes trip switch to trip out when `I turn the dial to switch on. Top oven is fine.
Likely the element is shorted in the main oven. The Calrod elements short usually at the bends and if the breaker doesn't trip they burn a hole in them and arc. You can USUALLY see a different discoloration at teh failure point. Check both upper and lower elements as preheat probably uses both. Use a dental mirror if necessary to see under and over. Use bright light.
May 04, 2011 | Tecnik TKC8525 Double Oven
Main oven trips electric when switched on top oven works fine also grill . did notice that fan was making a noise
If the fuse or circuit breaker is tripping it is most likely a short circuit in the oven element.
Feb 09, 2011 | Tecnik TKC8082 Electric Double Oven
Recently wired a double oven with isolator switch
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Cheers
Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
Tecnik TKC 8522 or 8525
hi if you contact tecnic should be in the manual they should be able to supply you with a new facia for the cooker good luck.
Mar 06, 2008 | Tecnik TKC8522 Electric Double Oven
Tecnik tkc 8522-8525
You need something thin and strong to slide underneath the screw head. Then turn slowly while lifting the screw head. The thread should catch and the screw should back out.
Mar 02, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Tecnik TKC8525 Double Oven Logo
457 people viewed this question
Top Tecnik Ovens Experts
ashburton
Raj Patel
Are you a Tecnik Oven Expert? Answer questions, earn points and help others
