Question about Sharp XR-32S Projector
BRIGHT SPOTS ON MULTIMEDIA PROJECTOR SCREEN: SHARP XR-32S-L USED FOR 2.5YEARS DISPLAYS MANY BRIGHT SPOTS ON THE SCREEN? IS THE PROBLEM IN THE DMD? SHOULD REPLACE THE DMD OR BUY A NEW ONE? DINESH MUMBA
BRIGHT SPOTS ON PROJECTOR DISPLAY. AROUND 10-15 IN CORNERS.USED PROJECTOR FOR 2.5YRS
    New Friend:
  • 12 Answers
It is the problam of your dmd chip i think the dmd chip 304 small like a simcard change the chip your problam will be solved 100%
i will show you the chip
BRIGHT SPOTS ON MULTIMEDIA PROJECTOR SCREEN: SHARP - dmd-hkperr0gfqj3xxcduav4mdvl-3-0.jpg
Posted on Feb 19, 2017
Sinista
  • 6 Answers
SOURCE: Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Posted on Jul 10, 2008
  • 3 Answers
SOURCE: sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
bgrenco@aol.com..
Posted on Feb 24, 2009
projdoc
  • 2236 Answers
SOURCE: Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Posted on Jul 23, 2009
  • 3 Answers
SOURCE: Cannot remove lamp assembly from Sharp XR-10X projector
Carefully try using a flat head screw driver on the middle plastic piece. make sure it is off...
Or try coming at it from the other side after taking the top of the machine off you can unscrew 3 screws and loosen whatever might be blocking it
Posted on Sep 08, 2009
projdoc
  • 2236 Answers
SOURCE: Sharp 4:3 projector shows blue at 16:9
if it's a lcd projector, the polarizer on the blue lcd is fried due to excessive dust and heat. when the lcd is blacked out, the light reflects back through the polorizer, causing more heat. you'll have to send it to a sharp service center for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Dec 16, 2009
Testimonial: "Sounds like very solid advice"
I am using Sharp multimedia projector XR-32S-L.There are white spots in the screen. What should I do to remove it?
white spot in image is comman problem of dmd chip it is fixed in to light engieen with heat sink replacment can possiable by expert
Mar 30, 2014 | Sharp XR-10X Multimedia Projector
I have white spots on my image from my projector SHARP XR-55X?
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD200
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 05, 2013 | SHARP ELECTRONICS CORP PROJECTOR, SHARP...
Spots on image
DMD (Digital Micro Mirror Device) replacement required.
Jan 14, 2013 | Sharp XR-10X Multimedia Projector
White dots appears in my screen. I replace the lamp and the problem is the same. (Sharp xr32x)
I would be willing to bet the DMD chip is failing the cheapest used one i seen was on e-bay the chip # will be something like 1076-6319W the only part of the # that matters is the last from what i have seen they tell me the 6318W and 6319W is suppose to be the same chip the used on i seen on e-bay was $124.00 probably better off seeking a new projector if you can not replace yourself as you will have over half of the cost involved hope this helps Robert
Aug 29, 2012 | Sharp "XR-32X-L DLP Projector"
Doesn't seem to recognise computer just got blue display on wall tried switching projector on first then computer on first still no luck
Have you tried another computer? have you tried toggling the FN key and your CRT/Icon key at the same time.
May 27, 2010 | Sharp XR-32S Projector
I have a MacBook Pro and a XR-30s sharp projector. When using the DVI port on the Mac to DVI-D on the projector the picture turn grainie. WHY? However, when I disconnect the cable, the pix clears up on the...
It is probably mirroring the screens on your MacBook and the projector. If you want different resolutions and things on each screen, go to the Apple menu, System Preferences, Displays, Arrangement and uncheck the "Mirror Displays" checkbox.
Apr 22, 2009 | Sharp XR-30S Projector
XR 10 X with low brightness with new lamp
dirty. colorwheel probably coated and needs replacing.
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
Sharp xr-11xc only displays black & white
Sounds like your connection is bad, check ur connections on ur cables
Oct 25, 2008 | Sharp XR-11XC Multimedia Projector
Sharp XR-32S Projector Logo
188 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
