Electricity bill coding in java
Please tell me the coding for calculating the electricity bill in java
    Problem Solver:
  • 19 Answers
First think how you would solve this problem yourself on a piece of paper. Then try programming it using the things you learned (if they've given you this assignment without teaching you to multiply, subtract and use if's, drop the course).
Well here is an idea.
Take the total kilowattage and send it to a function. What the function will do is subtract 14KW from the total Kilowattage and add the amount for the first 14KW then subtract 85KW from the total KW and add the amount for the 85KW. But once you subtract the number of KW from the total make sure to check if the total KW isn't negative, if so just break out of the function and return the total due.
Or if you have formula for how much the rate grows over how many miles.
For example lets say the rate grows by $1 every time the KW doubles you could have something like
int rate = 1; //Begining rate
int KW = 14; //First flat rate
int amount; //total amount they have to pay
while(totalKW > 0)
totalKW -= KW; //subtract the first rate
if(totalKW <= 0) //check if too much subtracted
break; //if so break
amount += rate; //add the rate to the total
rate += 1; // Add $1 to the rate every time
KW *= 2; // KW is doubled
Posted on Jan 09, 2009
Friend asked to store Aston Martin Vantage8 in my garage for a few months, and will need to plug in a trickle charger. What does the trickle charger do? and how much will it add to my electric bill?
Trickle chargers keep the battery fully charged.
They usually have a small cube-shaped transformer with a cord and plug or alligator clips.
If you look on the cube part label it will tell you the "wattage" , probably around 20 watts or similar.
This means while it's in use it draws 20 watts through your electric meter, the device that calculates your electric usage/bill.
You are charged for kilowatt hours.
To calculate how many kilowatt hours the trickle is using
multiply 20 X 24 hours X 31 days in a month .
Or 14,880 about 15 kilowatt hours a month.
In Florida a KWH is about 12 cents so it would cost you about $1.80 a month to trickle charge.
Dec 02, 2017 | Motorcycles
Wanted to do a good project on java.suggest d
if u have hardware knowledge,then u can interface a 4x4 matrix keypad with printer port and make a calculator!!
i have done this project, if u need hardware assistance tell me
Jul 14, 2010 | Sun Java Programming Language (cdj-275)
How to program calculator in java
If the question is : how to make a programmable calculator run a program written in Java, the amswer is : you cannot. Maybe the newer ones.
But if you are looking for the source code of a Java applet that simulates a calculator, then maybe you should launch a Google search with keywords Java calculator and see what you get. I do not want to spoil your fun by supplying a link to what my search returned.
Hope it helps.
Oct 09, 2009 | Canon Office Equipment & Supplies
F700v java activation code?
you cannot do that use the java download option beawre you may need to pay for the games
Aug 17, 2009 | Samsung SGH-E900 Cellular Phone
Calculator in java
<FORM NAME="CALCULATOR">
<TABLE BORDER=4>
<TR>
<TD>
<INPUT TYPE="text" NAME="Input" Size="16">
<br>
</TD>
</TR>
<TR>
<TD>
<INPUT TYPE="button" NAME="one" VALUE=" 1 " OnClick="Calc.Input.value += '1'">
<INPUT TYPE="button" NAME="two" VALUE=" 2 " OnCLick="Calc.Input.value += '2'">
<INPUT TYPE="button" NAME="three" VALUE=" 3 " OnClick="Calc.Input.value += '3'">
<INPUT TYPE="button" NAME="plus" VALUE=" + " OnClick="Calc.Input.value += ' + '">
<br>
<INPUT TYPE="button" NAME="four" VALUE=" 4 " OnClick="Calc.Input.value += '4'">
<INPUT TYPE="button" NAME="five" VALUE=" 5 " OnCLick="Calc.Input.value += '5'">
<INPUT TYPE="button" NAME="six" VALUE=" 6 " OnClick="Calc.Input.value += '6'">
<INPUT TYPE="button" NAME="minus" VALUE=" - " OnClick="Calc.Input.value += ' - '">
<br>
<INPUT TYPE="button" NAME="seven" VALUE=" 7 " OnClick="Calc.Input.value += '7'">
<INPUT TYPE="button" NAME="eight" VALUE=" 8 " OnCLick="Calc.Input.value += '8'">
<INPUT TYPE="button" NAME="nine" VALUE=" 9 " OnClick="Calc.Input.value += '9'">
<INPUT TYPE="button" NAME="times" VALUE=" x " OnClick="Calc.Input.value += ' * '">
<br>
<INPUT TYPE="button" NAME="clear" VALUE=" c " OnClick="Calc.Input.value = ''">
<INPUT TYPE="button" NAME="zero" VALUE=" 0 " OnClick="Calc.Input.value += '0'">
<INPUT TYPE="button" NAME="DoIt" VALUE=" = " OnClick="Calc.Input.value = eval(Calc.Input.value)">
<INPUT TYPE="button" NAME="div" VALUE=" / " OnClick="Calc.Input.value += ' / '">
<br>
</TD>
</TR>
</TABLE>
</FORM>
eNJOY
Jul 01, 2009 | Aquabot Robotic Pool Cleaner
Code for method parseInt() in java
parseInt(java.lang.String, int)
This code takes two arguments, a string constructor from the Java language and an integer. Its purpose is to parse (meaning de-construct or disassemble into component parts) one data type into another.
Here is an example of a Java program to specify and print out the dimensions of a rectangle, taken from the page http://www.roseindia.net/java/beginners/entervaluesfromkeyboard.shtml:
class Rectangle{
int length, breadth;
void show(int x, int y){
length = x;
breadth = y;
int calculate(){
return(length * breadth);
public class EnterValuesFromKeyboard{
public static void main(String[] args) {
Rectangle rectangle = new Rectangle();
int a = Integer.parseInt(args[0]);
int b = Integer.parseInt(args[1]);
rectangle.show(a, b);
System.out.println(" you have entered these values : " + a + " and " + b);
int area = rectangle.calculate();
System.out.println(" area of a rectange is : " + area);
Apr 09, 2009 | Sun Java Programming Language (cdj-275)
Calculate a bill
Hi you can Apply below mention formula
=ABS(SUM(COUNTIF(RANGE,"CATAGARI")-(COUNTIF(RANGE,"CATAGARI")))
RANGE = FROM WHICH CELL TO YOU WANT TO APPLY THIS FORMULA TO TILL WHICH CELL.
CATAGARI = WHAT DO U WANT < FOR FOR FIRST > FOR SECOND
May 22, 2008 | Excel (SS8SATAS5128400R)
Computers & Internet Logo
2,366 people viewed this question
David Payne
David Payne
