I chatted to marked about my akai home theater system progressive scan that has been turned on and he told me to unplug it for 6 hous well i have had it unplug for 3days know and i have just plugged it back in and it still hasn't reset it self can you please help so i can turn off the progressive scan???
  • mtllady Apr 04, 2009
    I have the same problem on a Philips DVD 727 player, can't get rid of the progressive scan, can anyone help?
    Brigadier General:
  • 6,966 Answers
Hi again,
For some reason we have had 2 disconnects. Either due to delay/lag or technical difficulties. Our apologies for the delay.
Posted on Jan 05, 2009
Why do my tv screen appears in three sections when i put a dvd disc? it appears normal when i put a vcd!
hi,
check is your tv supports progressive scan, if not switch off the progressive scan mode on your sony home theater system.
For switching off the progressive scan mode do the following in ur home theater's remote.
Do this setting if your connected the component video
1. Press the FUNCTION BUTTON on the remote.
2.Press the VIDEO FORMATE button to select interlace scanning.
If you are connected the HDMI then do the following setting
2.Press the VIDEO FORMATE button to select the resolution
Select 720 * 480p
Jan 17, 2011 | Sony BRAVIA DAV-HDX267W Theater System...
I am usin the components port to connect my Sony home theatre DAV-DX250 to my TV Sony Wega, and it doesn ot work, I just get static. Any idea what the problem is? thanks in advacne
You need to turn On Progressive Scan mode in home theater system to get video output in component video out ports so tv can show its picture.
Progressive Scan mode can be turned On by going into setup menu of home theater, details are available in user manual.
Thanks.
Nov 29, 2010 | Sony DAV-DX250 System
CD / DVD tray is stuck closed. Is there a manual bypass that I can open the CD / DVD tray?
No, unfortunately not. Open the unit by unscrewing the cover and ease the tray open while the unit is unpluged. Clean the area around the tray cover and try again. Hope this helps
Aug 17, 2010 | Progressive Computer JSI 6 spkr. Home...
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
May 23, 2008 | Audio Players & Recorders
How do you turn off progressive scan mode?
http://www.insignia-products.com/
I could show you the easy way,but you should learn it from the website!
Joe
Feb 03, 2008 | Progressive Computer InsigniaT 200W...
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
My home theater got stuck in progressive scan mode
I had this problem, it's a real pain. You need to turn the system on and goto Setup Mode, then count the number of tiems you would need to scroll down and reset it. You will see no picture, so you ahve to actually cound the number of clicks down and over, you are doing it blind, but it will work.
Sep 07, 2006 | Zenith DVT412 System
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
