Question about Canon I-Sensys Lbp5050 Laser Printer
My canon LBP5050 keeps going offline how can I get in back online
My printers keeps going offline for no reason, one minute it will be fine the next its off line ! I created an IP address high so this wouldnt keep happening but no joy ! Anyone know how to et it back online ?
  • 20 Answers
SOURCE: canon mp160
First step I would try is; unplug printer usb cable, then power down printer, reconnect usb cable to printer, power printer back on. If all this fails then lets try one other possible fix. Go to start select RUN & type services.msc, ok now you should have a services window that popped up. On the right hand side locate "Printer Spool" and right click on it, then select "Restart". this should refresh your printer spool. Hope this was helpful.
Posted on Sep 05, 2007
  • 10 Answers
SOURCE: Canon IR3300 would not scan when use the
If it is not an iR2200i with the i, then u cant scan
Posted on May 17, 2008
SOURCE: When I try to print my printer is showing as offline how do I get it back online
Phoned Canon today with the same problem. All I had to do was right click on the MP620 printer in printer control panel, then make sure that "Use Printer Offline"is not selected. Worked for me. Goodluck
Posted on Jun 18, 2009
SOURCE: printer not working wireless (printer offline)
Phoned Canon with the same problem. Everytime I installed the printer it would work until I rebooted. Canon advised that all I had to do was right click on the MP620 printer in printer control panel, then make sure that "Use Printer Offline"is not selected. Worked for me. Goodluck
Posted on Jun 30, 2009
pineworks
  • 4041 Answers
SOURCE: My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
How do i get my samsung ml-2510 printer back online? it is offline for some reason - was working in the past. tx!
Follow the step:
  • Access "Control Panel"
  • Access "Printers and Faxes"
  • Right Click your Printer
  • Select "Use Printer Online"
Mar 01, 2011 | Samsung ML-2510 Laser Printer
My canon printer says it's offline. how do i fix this?
Go to Start/Control Panel/Printers and faxes. Right click on the Canon icon and click on Offline turn toggle it back to Online. Please rate this answer.
Cheers
Bob
Jan 09, 2011 | Canon PIXMA MX310 All-In-One Printer
I made some copies last week and now my printer won't print. It keeps saying it is offline. I've turned it off, changed ports into the computer, shut the computer down, and tried most of the things I can...
  • Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Read more: How to Change a Printer from Offline to Online ' eHow.com http://www.ehow.com/how_4796279_change-printer-offline-online.html#ixzz16oE47d1K
    Nov 30, 2010 | Canon PIXMA MP780 All-In-One InkJet...
    Receiving consistence "printer offline" message. Printer will not print although the printer is on and is properly connected. Have checked it with the pc and the laptop. The printer is fine. Is there...
    Go to your Control Panel from the Start Menu. If your OS is Windows XP Click on Printers and other Hardware. Right click on your Canon Printer you are using .Scroll down to Properties. Click on Properties . It should give you the option to put the Printer in question "Printer Online". Click Printer Online. That should remove the option from Offline to Online .Then try to print from your Printer.
    Jul 31, 2010 | Canon PIXMA iP1600 Printer
    Vista says CANON MF4370dn printer always offline? IP addrs issue?
    first of all, download updated driver from software.canon-europe.com and install ( before install, remove old drivers and programs)
    and if appears again, change your network cable.
    Mar 29, 2017 | Canon ImageCLASS MF4370dn Laser All-in-One...
    It keeps telling me it's offline
    If printer is off line it needs to be set to "use printer online". If using Windows, go to ctrl/panel, open Printers, right click on your Cannon Printer. Move down to "Use printer online" and click on it. It should now work.
    Apr 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
    Nothing happens when i tried to print from my computer the status is offline what is wrong
    same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
    Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
    Canon MP 600 Will Not Turn On .... grumble.
    I had this same issue. Lost power in the house for just a second, but after the printer would not turn on. I think that the loss of power caused the printer to get stuck in a locked state. Tried everything I could think of including changing outlets that the printer was plugged into but nothing seemed to work. Saw a troubleshooting tip on the Canon webpage about unplugging the unit for 5 minutes and thought it was hooey, but tried it anyway. Ended up leaving the unit unplugged for probably 15 minutes and when I re-plugged it in it fired right up.
    Oct 09, 2007 | Canon PIXMA MP600 all-In-One InkJet...
    Canon i860 "printer offline" but light is blinking
    Move mouse pointer on to your printer icon in the Printer folder. Does a right click and click on the sixth line of the menu (“Use printer on line”). Then it will change as “Use printer offline”. Make sure the printer is set as default printer.
    Oct 17, 2006 | Canon i860 InkJet Photo Printer
    Canon I-Sensys Lbp5050 Laser Printer Logo
    213 people viewed this question
    old marine
    old marine
