Question about Water Heaters
Glow worm flexicom 30cx f1 fault
This boiler fitted 2010 i have just purchased house having been stood for almost a year. when started i hear the fan start but does not ignite just gives code f1. also no water comes from any hot tap, i have checked the valve is open. is this an easy fix or will i need a plumber?
  • 70 Answers
SOURCE: The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Posted on Feb 09, 2009
  • 659 Answers
SOURCE: Glow worm 45 60 boiler
You have to have 12" clearance on all sides.
Posted on Apr 03, 2009
  • 659 Answers
SOURCE: hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Posted on Apr 07, 2009
gasman44
  • 83 Answers
SOURCE: my thermostatic concealed shower valve only gives
If the hot and cold are fitted the wrong way round then the thermostat on the shower unit cannot operate properly!
Most thermostatic mixer showers have a 'bi-metallic' thermostat, if you supply the hot to the cold and vice versa IT WILL NOT WORK.
It is like wearing the left shoe on the right foot and the right on the left! It doesn't work.
Re-install the hot and cold to the correct supply, and this will sort it.
I hope this helps.
Posted on Jul 08, 2009
  • 4 Answers
SOURCE: vaillant eco tec pro 28 every time cold tap is
try reducing water pressure to cold tap and see what happens
Posted on Aug 04, 2009
Glow worm boiler energy 25s fault f28
ignition fault . There some videos on u tube about this
Feb 28, 2018 | Water Heaters
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
Combi boiler Glow worm 24ci digital fault
refere to glowworm expert advise
Apr 03, 2009 | Water Heaters
Apr 02, 2009 | Water Heaters
How water problem
Your should be able to find the information here. Don't forget to check under discontinued products. www.glow-worm.co.uk
Dec 03, 2008 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Water Heaters Logo
425 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
