Question about Samsung SMH8165B Microwave Oven
This oven is well taken care of, never abused, is used by adults only!
    Top Expert:
  • Samsung Master
  • 14,553 Answers
I presume if it has a turntable that works--there is a safety switch if not that will prevent heating.
Possible causes: bad diode, bad inverter board (diode could be there) that powers the unit for cooking and also a bad Magnetron.
Posted on Nov 08, 2012
cactus bob
  • 267 Answers
SOURCE: Bulbs UNDER the microwave burned out; new bulbs don't work
i know this is going to make no sense . but in my samsung service cd it is in BOLD PRINT YOU MUST DISCONECT POWER BEFORE REPLACEING BULBS , OR DAMAGE TO TIMER WILL RESULT ! the first time you changed them did you disconect power ? if not , your board might be toast , $$$$$$$$$
Posted on Jan 24, 2009
buddymcl777
  • 67 Answers
SOURCE: Samsung microwave oven turntable doesn't turn
Yes it just will not cook or defrost very evenly. It is not dangerous however.
Probably the motor or gears that make the turntable go are worn or burnt out.
Posted on May 01, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: I have a samsung smh7187 microwave over the range
I would suspect the oven cavity's thermal cutout / thermostat, the magnetron's thermal cutout / thermostat, and/or the fuse.
We have the service manual and have uploaded it to our site here to help you.
Note that your model number's suffix may be different than this manual covers exactly.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 06, 2009
2coolrick
  • 560 Answers
SOURCE: My samsung microwave oven is
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Posted on Oct 03, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: Does the exhaunst fan turn
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
Posted on Jan 02, 2011
Oven tempway out rang
yikes it appears that a thermister isnt working properly if not taken care of ASAP it could lead to some home damage please conact the oven's manufacture right away
May 06, 2017 | Microwave Ovens
Sharp microwave model R-530EK won't turn on. problem in door latch?
You could download the service manual from this website and go to page 11-1 for instructions on removal of top cover.You should then be able to access the latch from the side as it is under the control panel.
The manual also provides repair procedures on different problems.
You have to be vary careful with microwave oven interior and at all times when working on it the power chord should be taken out. There area also high frequencies and precaution must be taken and never turn on without the top cover back in place.
http://031d26d.namesecurehost.com/mwd//r530ekt_r530est_r530ewt_sm.pdf
Aug 27, 2014 | Sharp R-530EK R530EKT
Customer complaint
Most manuals advise you to use a soft cloth.
Paper towels scratch.
Maybe that's it...
Dec 22, 2013 | Neff Microwave Ovens
The whole power on microwave is off.
I suppose you checked the outlet for power. There is a (15 Amp slow blow) fuse inside the oven. that could be blown. If that is the case, just replace it. If, after replacing it, the oven works Ok you will have taken care of the problem. If, however, the fuse keeps blowing when opening / closing the door, that means that there is a problem with the door switch sequence. If this seems to be the case and you want to get into that, I would have to walk you through it, step by step. I would need to find out how to do that as per FixYa rules.
May 09, 2011 | GE JVM1540DM Microwave Oven
It is made by sunbeam I suppose.The model no. is ogg21401.The microwave works but will not heat.It could be stuck on defrost,thats the last function we used.We've only had it a little over a year with just...
99% of the time when a microwave is not heating at all, this means a busted MAGNETRON, and is usually almost as expensive as a new oven... sorry!
Apr 18, 2011 | Microwave Ovens
I don,t know how to use the microwave to boil water or warm food quickly.
Microwaves differ in power so you need to determine how long it takes your microwave to boil water. Great care should be taken as because if left to cook too long, water can become super heated and cause serious injury.
To determine how long yours takes, put about a cup of water in a microwave safe mug with a handle in the center of the oven and run it for about 1 minute. Remove VERY CAREFULLY and check the temperature with a meat thermometer. Repeat until you get the water up to about 180 degrees F. Note the number of minutes and use that going forward.
Mar 05, 2011 | Microwave Ovens
Remodeled kitchen axly 4 years ago. Whirlpool MT2145SJ (number taken from use and care guide) microwave installed above range. About month or so ago, the fan quit running during the microwaver time, and...
Hello, unfortunately we are not trained technicians and we cannot advise you how to repair the unit. We would always recommend resetting the appliance by removing the power for 2-3 minutes. If that does not correct the problem we would suggest having a certified technician properly diagnose the problem that you are experiencing. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased your appliance to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 18, 2017 | Whirlpool MT2145SJ 1100 Watts Microwave...
Will an over the range microwave exhaust fan start automatically If the range cook top gets too hot.
NOT THAT I'M AWARE OF . YOUR UNIT SHOULD HAVE A SWITCH TO TURN ON AND MUST BE TURNED ON MANUALLY
Oct 12, 2009 | KitchenAid KHHS179L Convection/Microwave...
It just went dead. from working great(7 years old
Blown fuse. Remove the outside cover and should be located near the area where the power cord enters the unit.
Jun 03, 2009 | Amana Radarange Microwave Oven
Can't remove it from above the range
check back side clips and remove the topcover carefully, check the all locks, and clips,
Oct 04, 2007 | LG LMV2053 Microwave Oven
Samsung SMH8165B Microwave Oven Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
