Question about Wacom Intuos3 Graphic Tablet
My ExpressKeys seem to be functioning as toggle instead of hold. How can I restore the hold functionality?
  • dashxl Jan 05, 2009
    For some reason, I had sticky keys on... I feel sheepish.
I had sticky keys turned on. I disabled sticky keys and it worked like a charm.
Posted on Jan 06, 2009
Wireless capability won't turn on
Make sure you Press and Hold the FN function key then hit the F2 key.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
Jun 02, 2012 | ASUS K40IN Notebook
How do I activate the wireless function?
Does the laptop have wireless capability? Is there a wireless card inside the laptop?
If so, look on either side and at the front of the laptop for a Switch that turns the wireless on. Once you have the wireless switch on there are keystrokes that you can use to toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left portion of the keyboard then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it or it will have the icon of a tower with the wireless signal icon )))).
Apr 25, 2012 | Toshiba Satellite Computers & Internet
I have a cda-9883 alpine that is in demo how can i take it off demo and have it play normal?
hold down the function button until the display changes. you can then toggle things like dimmer ,aux, and demo by turning volume control. when you see demo push the play/pause button which will then allow you to turn it off by again turning the volume button. once its off press play/pause button which will allow you to toggle other functions. then hold function key down again to get back to main display(main display will eventually return on its own)
Dec 10, 2010 | Car Audio & Video
Cannot use right side numbers of the keyboard, other functions ar
I'm not sure what keyboard you have but there should be an "Fn mode", "Mode" or similar button on your keyboard, it should be the same color as the function icons on your other keys. This is usually used to toggle between the different modes. If this doesn't work or only works while your holding it down then you'll need to find the setting software for your keyboard. It's most likely in with your other programs or in Control Panel, some will put an icon in your task tray that you can double click or right click to access them.
May 02, 2010 | HP Multimedia Cordless Keyboard/Mouse...
I hit some key and now when I try to insert letters between words instead of inserting it gobbles up the letters ahead of it.
You did not say which program you were using, but in most cases the "Insert" key on your keyboard toggles between the Insert and Overwrite functions of the software. Pressing the Insert key again shoudl fix your problem.
Aug 05, 2009 | Computers & Internet
None of my F-keys seems to be working... I run in Windows 7. All the other keys are working fine.
It may happen that ur keyboard drivers are available and u have not properly installed so according to me first uninstall and then reinstall it.It may work
Aug 03, 2009 | Logitech Cordless Desktop Ex100
Garage door remote
It sounds like the lock function has been toggled on. Press and hold the button on the wall control with the lock icon for 3 seconds. This will toggle that function off.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
May 22, 2009 | Acer Aspire One PC Notebook
F keys suddenly not working
The "F mode" button toggles on and off the F keys. If you press it (accidentally) as I did, the keys will no longer function.
Simply press the "F mode" key again (it is directly above the "End->" key between F12 and Insert on this model keyboard) and functionality will be restored.
Apr 08, 2009 | Logitech Computers & Internet
The function key is stuck on my Dell laptop
Just press the funtion key and the Numberlock key
FN + NmLk (Usually on the same key as delete)
Please rate this a fixya
Feb 08, 2009 | Dell Inspiron 1501 Notebook
Wacom Intuos3 Graphic Tablet Logo
90 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
