Question about AEG Washing Machines
Circuit board for a AEG Lavamat 74689 is it possible to buy one?
An AEG recommended engineer says the circuit board has stopped working but that replacements are no longer made. Where should I search for one?
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
localwonder
  • 6784 Answers
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Posted on Jun 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: AEG Lavamat 518 manual
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
SOURCE: i want circuit daigrame for aeg washing machine
I have an AEG öko Lavamat 64600 washing maschine and I need a circuit diagram. Can you help me?
Thanks,
Bridget
Posted on Nov 22, 2010
AEG Lavamat 74689 Update wont pump out
Possible that the program timer is faulty as it fails to switch on the pump in the required sequence. You can clean the contacts, check the power to the pump, trace the pump power line to the timer which can confirm the case. In such cases the timer must be replaced.
Jan 02, 2013 | Washing Machines
How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Jul 17, 2010 | AEG Lavamat 74640 Front Load Washer
Aeg electrolux lavamat 74820 e91 fault
  • It indicates that there is no communication between circuit boards.
  • Power off, drag machine out onto the floor, remove covers, disconnect circuit board connectors and clean with a toothbrush.
  • Clean off any corrosion or crud, refit and test. Closely inspect the entire wiring loom and circuit boards, looking particularly closely at areas where the wiring touches the machine frame. Your'e looking for any signs of wear or fraying, which would allow the bare wire to contact the frame.
  • Check all wires and connectors generally for internal breakages caused by movement of the wiring loom attached to the drum.
  • If you could not find any torn wires call service technician to repair the washing machine .
Hope this helps .
Shane
Dec 06, 2009 | AEG Washing Machines
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
Oct 28, 2017 | AEG Lavamat 72640 Front Load Washer
I want circuit daigrame for aeg washing machine
Thanks,
Bridget
Dec 30, 2008 | AEG Lavamat 88840 Front Load Washer
AEG oko-lavamat 72630 update
It is a communication problem between the circuit boards inside the machine. It might be as simple as unplugging and replacing the wires, or you may indeed require a new circuit board.
Aug 05, 2008 | AEG Lavamat 72640 Front Load Washer
2 problems here with my AEG 72640
we had a similar problem(45mins) we were about to purchase a new one when by sheer luck i noticed the on/off socket(not plug) above worktop was buzzing, pulled machine out put in different socket and has been ok since. Try it, it could help.
Jan 25, 2008 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
