Question about Moen & One Handle Tub & Shower Faucet
How do I remove the water restrictor from a Moen shower head?
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
Posted on May 16, 2010
  • 185 Answers
SOURCE: Just installed a Moen 3867 hand held shower. There
Usually whenever you do any repairs on plumbing, you dislodge calcium from the inner surfaces of teh plumbing. Check to see if ther is a mesh filter in the inlet side of the head. and remove and clean it. otherwise you could remove it and use a vacuum yo try and remove any deposit that may be in it. If that is unsuccessful,
you can always return it, but always remember to open the fawcett and run it before installing the head.
This is an essential part of any plumbing job. Good luck
. If your local store refuse to replace it Moen will gladly do so with no problem.
They are good like that.
Posted on Mar 04, 2010
How can I remove the flow restrictor in the shower? I have terrible water pressure.
You need to tell us what shower head it is. Usually the flow restrictor is in the section that screws onto the pipe that goes into the wall. Be careful when you take it off so that you don't mar the chrome finish,
Aug 23, 2014 | Moen 7175CSL Level Single-Handle Kitchen...
Installed a new faucet and no water comes out
Since your question is so vague (is it a shower, tub/shower, lavatory, kit. sink or laundry tub faucet) I'd have to say that the flow restrictor in the aerators or showerhead is clogged up. Just unscrew and remove and either clean aerator or sh.head out and/or remove flow restrictor permanently. If that doesn't work turn off water and disconnect supply tubes from faucet and run them into a bucket and turn water back on to check for volume. If you have plenty of water at supplies then remove faucet and take defective faucet back to where it was bought and get another one!
Jun 08, 2014 | Moen & Replacement Cartridge
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
I have a Moen single handle tub/shower faucet. I cannot yet get much pressure to the shower head, there is good pressure from the faucet. I have placed the shower head in vinegar with no improvement. ...
Your problem is in the water restrictor located inside the shower head. All plumbing manufacturers install these small plastic internal blockers to reduce water down to 2.5 gals per minute. In your case, this restrictor is most likely filled with sediment which is restricting it even further. Remove the shower head from the curved shower pipe. Look inside where the water goes through it. You should be able to see the restrictor. Maybe you can flush out the sediment. Otherwise, remove it and I'm sure you'll get more pressure then originally installed. Because most restrictors are sort of plastic screens or cones, I usually put a wood screw through the center of this product and then once a few threads bite in, I use a plyers on the head or the screw and pull outward while holding the shower head in a stable position. If you are able to get it out, technically your "out of code" because now your going to get all the water it can really supply.Most people are delighted to have it gone.
Nimsgame
Feb 14, 2011 | Moen & One Handle Tub & Shower Faucet
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
I have a posi temp faucet that has been installed for 6 years but never used. Now i have the project completed and have no water pressure thru the shower head. The sink has lots of pressure and is on the...
Have you disassembled the shower head to see if it has a flow restrictor in it. If it does you can remove it and any aerator type screens. Hope this helps. Thanks
Dec 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
Flow restrictors
Remove the shower head from the arm and look inside the connector on the showerhead. You should see a plastic or metal piece that will either unscrew or need to be pulled out with needle nose pliers. Once that's been removed the flow should be improved.
Apr 19, 2010 | Moen & One Handle Tub & Shower Faucet
Just installed a Moen 3867 hand held shower. There is no water coming out of the head. Water flows just fine from the hose without the head attached. Is there a restrictor plate or something I can...
Mar 04, 2010 | Moen 3867 Four Function Hand Shower With...
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen & One Handle Tub & Shower Faucet  Logo
162 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
