Question about DeLonghi Caffe Parma Espresso Machine
Delonghi, Cafe Latia
Got a great expresso machine that now seems to be leaking. When turned on, and as the light turns on signaling that the water is now hot and ready, there seems to be water already coming out of the dual dispensing coffee grind holder. Then, after it's made a double shot, it continues to dispense a small dripping amount of water through the system. i have to put a small container under the dispensing outlets to catch it. it will let out another shot or two of water after i have made my drink and have walked off. what's up. is it just old? it's probably 10 years old and has been a great machine. stephen please feel free to email me directly at stephenhaley @ att.net
  • 143 Answers
SOURCE: Describe your DeLonghi Caffe Nabucco BCO70
requires replacement group seal and or coffee ground too fine
Posted on Sep 14, 2009
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
mcdevito75
  • 1970 Answers
SOURCE: i need a manual for my delonghi cafe parma machine
mcdevito75 here, You may be able to get the manual online at Delonghi Caffe espresso machine.
Posted on Jun 20, 2010
  • 18 Answers
SOURCE: Hi, We have just bought
Sounds like you need to prime the water pump. Remove the filter holder, open the steam knob and then press the coffee delivery switch. Wait for water to flow consistently from the steamer and then close the steam knob. Water should then be forced to flow through the goup head (coffee head). If you cannot get water to flow from steamer then the pump may have already been damaged or it may have been faulty from the start. If water will flow through steamer but not for the coffee, then the group head is blocked. Good luck hope this helps and remember that all machines should be primed like this before use.
Posted on Dec 15, 2010
  • 155 Answers
SOURCE: help received the Delonghi Cafe
http://www.manualnguide.com/dl/10372/
Go to the above link and download the manual for the BCO 120T
It should provide the basics to get you going
Making a good espresso with steamed milk takes practice
If you don't have the frothing pitchers.. buy a couple in different sizes
Used cold low fat or non fat milk..
It takes practice to get good at it.. a hand on the side of the pitcher to make sure you don't scald the milk.. etc.. you don't want the milk to bubble/boil..
If you have a control valve for the steam pipe.. immerse the pipe about an 1/2 inch or so into the cold milk and slowly open the valve.. until you have it open full. Jostle the pitcher to move the milk around pretty much during most of the process once it begins to warm and foam.. raise the pitcher to heat the milk in the bottom .. then lower it as the foam begins to form...never letting the steam pipe out into the froth. Once done..wipe the pipe clean with a wet cloth.
Grind of the coffee is imporant as well as the roast and when you fill the portafilter don't over tamp.. If you pack it to tightly.. won't brew... too loosely.. brews too fast.. You want to see the coffee shots come out and form what's known as crema... which is a thin layer of tan or light brown foam on top of the shot. If aren't getting this..the coffee is either ground wrong or packed too tight.
It's an art..and nothing beats practice.. there are scores of books and internet threads on how to froth milk and make different coffee drinks..
I love a good Cafe Borgia now and again.. we live in the Portland, Oregon area.. everyone here is addicted to the bean..
Best of Luck
Posted on Apr 29, 2011
I need help understanding how to descale delonghi expresso machine
hi Kathy.
see if this helps you out.
For machines without an automatic descaling cycle:
  1. Dissolve the descaling agent into a full reservoir.
  2. Pull the solution into your boiler by running about a cup of water out of your steam wand. ...
  3. Turn off the machine and let sit for 20 minutes. ...
  4. After 20 minutes, run about 1/2 of the reservoir out of the steam wand.
How to Descale Home Espresso Machine
or try this link.
how to descale delonghi espresso machine Google Search
Dec 12, 2017 | DeLonghi Coffee Makers & Espresso Machines
The water light, will not stop flashing, on my DeLonghi cappuccino expresso machine. Tried turning machine off, water tank is full, filter in place. It does not appear that valve is stuck.
There's a float in the watertank that should go up when the tank is full. A sensor in the machine will tell it that there's enough water in the tank. So, the float can be stuck, if not then maybe there's something wrong with the sensor. Or, worse, the main board is broken. Hope this helps a bit.
Nov 23, 2015 | DeLonghi Coffee Makers & Espresso Machines
My Coffee machine Delonghi doing expresso without foam today. Before doing good expresso with foam. help please.
Espresso should have crema not foam, foam is air added to coffee, like Starbucks does. Issue lays in the grinder and coffee quality. Recommend using Italian espresso bean like Miscela d Oro
Apr 14, 2014 | DeLonghi Coffee Makers & Espresso Machines
Water leaking from underneath my delonghi ec330s
There could be a loose hose, or a hole. Try to call the number the expresso came with.
Feb 08, 2014 | DeLonghi EC330-s Pump Espresso Maker
I can not get my expresso to come out, I had no manual with this product. Ariete elisir cafe model 1331
Once you have put the water into the reservoir, you have to turn the machine on (top button) and then let it heat up for 8 - 10 minutes before you turn on the espresso maker button (middle button). Once you're halfway through making your espresso, I would recommend turning on the frother button (bottom one) in order to get up the steam if you're going to make steamed milk.
I hope this helps.
Jul 26, 2011 | Ariete Cafe Retro Espresso Machine
How do you descale the machine,as we have no manual
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
Jun 14, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
The CLEAN light has come on. How do I clean it?
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
How to flush Delonghi Macnifica Coffee Machine - not latest model
I bought a cafe parma (delonghi) on e-bay and was disappointed that it was so mineral-encrusted when it came. I was afraid to even plug it up -- much less run any water through it.
I mixed up hot water and vinegar and poured it inside. Lots of solid flakes emptied out the top a couple of times. Then I mixed up a final solution of water and vinegar and ran it through the machine.
I had been running a motorized Hamilton Beach model for about two months. And it had quit siphoning water. I couldn't find the Black and Decker or Mr. Coffee models similar to the one I had been running for years. They looked the same as the Cafe Parma model.
Now my Cafe Parma is making great expresso!!! I'm getting ready to take the Hamilton Beach apart. It will probably end up in the trash. It was 40 bucks on clearance at Wal Mart.
Mar 18, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi Caffe Parma Espresso Machine Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
