Question about Philips Magnavox 27MS343S 27" TV
Popping sound I have this TV for a year now, several month before when i plug the TV to the power line and turn the tv on by a remote it pops like a ballon bursting sound and continues until now when i turn it on by the remote it pops once and the TV is dead. Now when i plug the TV to the power supply its power indicator does not respond. The TV has no power at all. Any solution for this?
  • 666 Answers
We need to trouble shoot this parts by parts, first to check is form power supply section, hang first the h. out transistor and b+ con. to fly back transformer to be sure no burning parts when testing, if b+ v. normal proceed checking horizontal section of course check that h. out transistor good. and trace again.
Posted on Mar 29, 2010
    Sergeant:
    Champion:
  • 318 Answers
If you had taken your tv ealier for repaire it had a switch problem, the sound you used to hear were arcs in a switch, but now it has a disconnection in side it. the problem is not very big. thanks
Posted on Mar 20, 2009
Testimonial: "thanks!"
What might be the problem with tv making popping noise when turned on
you must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
Apr 05, 2015 | RCA L32HD31 32 in. LCD HDTV
My 50" LCD TV makes a popping sound when it is first turned on. It is about 6 months old. It has done it when it was storming. But the weather is beautiful and it started popping when we first turned...
Hello
A poping sound will be there for most of the TVs when it is switched ON, using its power ON/OFF switch at its front panel. There will be no such sound when you power On it by using its remote control. If it pops up still when you poower it ON using remote control, the set need service. As it is new, it will have warranty. just contact the dealer whom you bought the tV. company must repair it for free.
Feb 27, 2012 | Televison & Video
4 year old 50PC1DRA LG Plasma tv. TV would come on after several tries, now will not turn on at all. Just clicks. From what I read here, could be power supple? Is a 4 year old TV worth putting that...
It's the capacitors on the power supply, it's a common problem, either buy a capacitor repair kit (yes they make them) and have a TV tech solder them on, or buy a new power supply board (about $200) and remove and replace it yourself (it's that easy)
Oct 24, 2010 | LG 50PC1DRA 50 in. Plasma Television
Their was a blackout in my neighborhood. The next day in the morning i tried to turn on my 50inch HP Plasma and it made a loud popping sound. The volume on the tv still works.
Hello.
You probably did not have that tv plugged into a surge protector. When the power was restored, a surge came through the line. A power surge is a spike in voltage above the maximum a tv, appliance etc. can handle of 169 volts. They are very brief, usually lasting millinths of a second. Power surges can vary in duration and magnitude, varying from a few hundred volts to several thousand volts.
That said, now what do you do. If the tv is under 3 years old I recommend that you take it into a local TV repair shop for a free estimate of repair. If it is older than that, I would not repair, just replace. J.
Sep 12, 2010 | HP Televison & Video
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Sanyo Television PLV-55WHD1
i heard same popping sound and my power button flashed red and will not turn back on.?
Sep 15, 2008 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
No sound on Sharp Aquos 37' LC-37D4U
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
No Sound
hi there, it maybe the jack were you used headphones, try to replace the jack and see if there are some cold solder at the amplifier section. test some parts. ty
Dec 29, 2007 | Memorex MT2206 TV
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Philips Magnavox 27MS343S 27" TV Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
