Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Ice maker output very low volume
My icemaker used to pump out ice at a very pruductive pace. Almost overnight it went from full bore to a trickle. I'm lucky if I get one cycle a day. Also I've seen water trickling down inside the back of my frig and have seen puddles of water on the frig floor and on shelves.
  • 163 Answers
Hi!!! check your filling tube line going into the icemaker its a white tube that gives water to the icemaker.It might be plugg of ice..get a hai dryer and aim it for 30 minutes good luck..
Posted on Jan 05, 2009
PFSF5RKZC Icemaker stopped making ice.
Most of the time is the ice maker itself that is defective. inside ice maker is an small circuit board that freezes up, if you take ice maker out and leave it overnight out to melt any ice inside the board it may work after that.
Apr 03, 2014 | GE Refrigerators
U Line Ice Maker not working at all
if your drain pump is the one you plug your ice maker into and then the pump into the wall plug the pump is full and will not let the ice maker run. must be something wrong with pump
Nov 14, 2013 | U-Line Icemaker
Water flow to ice maker has been reduced to
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | General Electric GSS22JET Side by Side...
Too much water in amana bottom freezer ice maker
Try closing the valve partially on the incoming water to the icemaker. Close it to a trickle. Water is fed to the icemaker by a short timer. Too much water pressure means too much water. If this helps it but not solve it, get the spec sheet for the icemaker and adjust to make cubes smaller. This shortens the timer. If no joy, you may need to replace icemaker module.
Sep 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
The freezer door was ajar overnight and now the icemaker is leaking water
chances are alot of the ice melted overnight. remove all of the ice cubes, dry everything out and then wait a full 24 hours for the icemaker to produce ice cubes.
Aug 28, 2009 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water runs, but no ice being made.
check if the fan near the condenser is still running.
check also the lever if it is in the down position. if it is in the up position, that means you turn off the ice maker.
check if there is frost on the freezer, if it is cooling very well.
keep me posted,
drcool
Oct 14, 2008 | U-Line Icemaker
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
Dec 31, 2006 | Amana ARS266ZBS Side by Side Refrigerator
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
572 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
