Question about Sanyo Microwave Ovens
How to replace microwave bulb sanyo em-g2551 - Sanyo Microwave Ovens
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave runs when door open
This is probably a a bad door switch or door switch mount. Chances are only the fan and light are running when you open it, but better safe than sorry. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure but not the only one. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files by searching at Yahoo.com (not Google) for this: microwave display safety.txt If you still have a problem, please write back with more detail. Be safe!
Posted on Nov 21, 2006
SOURCE: Service manual of microwave SANYO EM-D953
hi
If you are still looking here is tthe link for the instruction manual for that model which is the same one i have used for years
http://www.sanyo.co.uk/download/1659661.pdf
Have fun
Posted on Jul 04, 2008
tiway1
  • 100 Answers
SOURCE: Turntable motor - Sanyo Microwave Model EM-S8000W
There are actually two, both Panasonic motors...
Here are the full links...
http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-253w-b6326408ap-p-215.html
http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-6rpm-f63265g60ap-p-217.html
Here's the link to their main page for motors...
www.martinmicrowave.com
Posted on Sep 06, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Change light bulb in Sanyo Microwave EMS6786V
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Mar 06, 2009
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
How do I fit a new bulb into my sanyo EM-SL30 microwave.
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Mar 08, 2011 | Sanyo EM-Z2100GS Microwave Oven
How do I change the lightbulb in the unit?
remove the screws holding the outer shell and carefully remove it.... the bulb should be accessable then. make sure the replacement bulb is equivelent to what is in the microwave now. do not operate the microwave without the cover on it. if possible test the bulb before you put it in.
Jan 17, 2010 | Sanyo EM-P410W Microwave Oven
Light is burnt out. How do I replace the bulb for an EM-S260
Befor you do anything you need to read up on how to discharge a high voltage capacitor so that you avoid all sort of injury as well as death. Once you have read up on how to discharge the high voltage capacitor, you simply remove thecasing of the microwave, discharge the high voltage capacitor, once that is done, you are safe to locate and replace the bulb, To obtain a bulb contact your closest Sanyo authorised repair agent, they should either have one in stock or they will be able to order one for you.. Good Luck.
Dec 02, 2009 | Sanyo Microwave Ovens
How to replace light
there is either a panel on back of unit you can remove and light bulb is there, if not you will need to remove case to change bulb.
Nov 25, 2009 | Sanyo EM-S5002W Microwave Oven
Replace light bulb on SANYO EM-U1000W Compact Microwave Oven
PLESE BEFORE YOU DO ANYTHING RFER TO A GUI HOW TO DISCHARGE A HIGH VOLTAGE CAPACITOR OR SEEK THE HELP OF A MICROWAVE TECHNICIAN. As for changing the bulb, if you remove the case you will be able to locate the bulb, and merely a case or removing ad replacing with a new one. Good luck.
Nov 16, 2009 | Sanyo Microwave Ovens
How do i change bulb in sanyo microwave EM-SL30N What do i do must i take the cover off what is the easy way please.
Make sure it is unplugged. Yes you must take the cover off and you will see the bulb. Gain access to it and replace it. Do not interfere with anything else.
Nov 09, 2009 | Sanyo EM-Z2100GS Microwave Oven
Replace fuse in sanyo em-z2000s microwave onen
try replacing the fuse.there might just be a voltage fluctuation in your locality
Mar 16, 2009 | Sanyo EM-Z2000S Microwave Oven
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Sep 16, 2008 | Microwave Ovens
Microwave Ovens Logo
47 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Oscar Netto
Oscar Netto
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
