Question about Acer Aspire™ T180 PC Desktop
I have just purchased a new SDHC 8GB disc but my pc will not read it why is this?
    Sergeant:
  • 367 Answers
Are you looking for the Flash memory in my computer. It should be listed as another drive letter.
Posted on Jan 05, 2009
My fujitsu doesn't read SDHC 16GB
If there is a BIOS update, that may help.
Sep 06, 2014 | Fujitsu LifeBook E751
My Acer 3692WLMi does not read my Fuji 8 gig SDHC card but it will read my Panasonic 2 gig SD card. Can someone give me an answer/solution. Thanks C
While I'm not directly familiar with this Acer model, it looks to be an older laptop. It's almost certain that it was built prior to the SDHC cards being created - a lot of older memory card readers are not able to read the High Capacity (HC) flash cards. I actually own a couple of devices that also would not read the 8GB card.
To test, I would recommend finding a newer USB SD card reader that you could either borrow or purchase (they're usually not too expensive) to see if that reader could get the information from the SDHC card.
If that works, the problem would be that your flash card reader does not support the higher volume cards. This is the most likely possibility.
If it doesn't work, there may be an actual problem with the SDHC card itself.
Hope this is helpful!
May 13, 2011 | Computers & Internet
I have just purchased a casio EX- H5 what sdhc memory do i need or which one is best.
Your camera can use SD or SDHC cards. I recommend SDHC because of their larger capacity. If you plan to take videos, I recommend a class 6 or better SDHC card of 8GB or more. Enjoy your new camera...it's getting very good reviews everywhere.
Oct 15, 2010 | Casio Cameras
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
I purchased a new memory card (sandisk sdhc ) it will not format?
Get a new camera :-)
Seriously, the Z740 is designed to work with SD cards, not SDHC cards. While SDHC cards will fit into the camera, they will not work. You need to buy SD cards 2GB and smaller.
Jul 26, 2010 | Kodak EasyShare Z740 Digital Camera
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
It doesn't read 8gb sd cards on internal sd drive
There are two types of SD cards. The first, standard type, had a capacity limit of 4GB. But quite soon the technology advanced and higher capacity Flash memory has been developed, so the standard had to be revised - and SDHC was born (HC stands for High Capacity), which includes cards having 4GB and above.
There is an overlap, as you can see, because there are 4GB CD cards, and 4GB SDHC cards on the market.
Now your DELL is an older machine, and it's card reader is not compatible with the new SDHC standard. And it will not be, even with a BIOS update.
You have two options: find a 4GB SD card (they are hard to find, majority will be SDHC) and stick with this capacity, or purchase an USB SD/SDHC card reader, which is cheap, and use it to transfer files to/from your 8GB card.
Nov 22, 2009 | Dell Latitude D430 Notebook
R4 SdHc
It wont read anything higher than a 4gb card!!
May 31, 2009 | Nintendo DS Lite Console
Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
Acer Aspire™ T180 PC Desktop Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
