How to connect speakers to the SANSUI power amp B55
At the back of this power amp are "strange" speaker connectors, you can twist/turn these a little but I can't see how to connect the speaker wires.
Duncan
  • 218 Answers
SOURCE: Need help in wiring speakers to amp.
The right speaker will connect to the R+ and R- terminals and the left speaker will connect to the L+ and L- terminals. Only one speaker per connection. If both speakers are not exactly the same brand, part number,size, etc. then they may NOT sound the same. Be sure to watch the polarity of the speakers so they don't interfere with each other. I.E. speaker + to amp + etc. Good luck.
Posted on May 11, 2007
SparkGap
  • 363 Answers
SOURCE: Hooking up speakers to amp
YES ! This is usually ok, the speaker cabinet should contain a high pass filter or crossover on the tweeter to decouple it from the low frequency signals. My Linn Index speakers are wired like this.
Posted on Sep 22, 2007
  • 15 Answers
SOURCE: Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
Posted on May 27, 2008
SOURCE: Sony speaker connectors
Try this guy on eBay who is selling 2 varieties of Sony connectors, plus a ton of others
http://stores.ebay.com/BOGUE-ENGINEERING-GROUP
I'm about to pull the trigger on a set of his 4.2mm connectors for Sony HCD-HDX500 for $26
Posted on Oct 11, 2008
SOURCE: Sony DB930 - Rear right speaker (terminal connector?) not working
These receivers have a common fault with the relay on the amplifier board. If you open the lid, the rear amplifier PCB is on-top in the centre. The relay is in the middle of the board. It should be easy enough if you have a multimeter to check the contacts are closing correctly, if not then replace it, the specs are printed on the side. If you are not confident then don't try it, these are powerful amplifiers with +/-60v DC rails. 120v DC can do you some damage if you get it wrong!!
Posted on Feb 11, 2009
How do I connect a center channel speaker up to a vintage sansui amp?
It depends on the amp. Can you connect more than two speakers to it? If it has a four speaker connector say A/B place the center on the B and use the A/B switch to power all the speakers.
Feb 22, 2015 | Sansui Audio Players & Recorders
On my Sansui sw-100 sub, I have 2 speakers connected to the high level output, that dont operate
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
Jan 15, 2014 | Audio Players & Recorders
I have a Sansui 2000A Stereo Tuner Amplifies that powers up but has no sound. the fuse for the 220-250V 2A was blown and replaced. The speaker fuses look good. Should I replace them too or is there...
If the fuse was blown on the 220-250 V side, I am assuming that you are in the UK, if you aren't , but are in the US, change the power setting dial/switch on the back to 100-120v and you might be good to go. Also, I know this may sound silly, but make sure that the speaker selector switch is pressed in or set to a speaker set ( A or B). Love the Sansui gear, have many complete systems myself!
Oct 17, 2013 | Sansui Classic Vintage 2000a Stereo...
Sansui G-5700 protection light wont go on
Try checking the speakers and connections. Those symptoms occur if there is a short. Disconnect all spkrs, turn it on and if it stays on connect one speaker at a time until it shuts off.
Jan 19, 2013 | Sansui G-5700 Tuner/receiver
Off of the top of your head could you tell me what my problem with my sansui AU-717 amps problem could possibly be? When I am playing a cd if the volume is even barely loud the sound will go out then I...
It sounds like one of the following:
> You have an impedance miss-match between your speakers and the amp (speakers have am Ohm rating lower than the amp can handle),
> You have the switch set to both A&B speakers turned on, but have speakers connected to either the A or B set, but not both, or
> You have both A & B (4 speakers) connected, and one or both have an Ohm rating lower than 8 (if two sets are connected, they must be 8 or higher).
My best guess off the top of my head.
Apr 07, 2011 | Sansui Audio Players & Recorders
How do I wire the system
You would require an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire.
The complete installation process is as follows
#1
Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
#2
Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Ideally the speaker wire will be connected to the old speakers with a metal clip that can then slide right on to your new ones. If not, cut the wire off the old speakers, strip about half an inch of it, then cut the last 6 inches or so off the speaker wire that came with your speakers so you have the proper connectors with a little wire attached, strip a half inch of those wires and twist connect them to the existing speaker wire. Bend the twists so they are in-line with the wire and wrap each connection in electrical tape so no wire is showing to protect them.
Attach the connectors to your new speaker. Make sure to connect the negative wire (-/black) to the negative terminal on the speaker and the positive wire (+/red or white) to the positive one. Screw the speaker in place. If you have component speakers, and therefore a crossover, make sure the crossover is secured in the speaker compartment so that it does not bounce around while you drive.
Wait to put the speaker enclosures back together until you have installed the head unit.
#3
Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
If the speaker wires are separate from the harness connect them using the method of stripping, twisting, and taping described above. Do this one at a time or use masking tape to label the wire to avoid confusion. If you are having trouble figuring out which wires go to which speaker or which is positive and negative read the tip at the bottom of this section.
Do not put your new head unit into the dash yet-you still need to connect the amplifier to it. Put the speaker enclosures back together now.
#4
Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
#5
Put the fuse in the fuse holder.
#6
Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
#7
On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
#8
In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
#9
Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
#10
Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
#11
If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
#12
Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
#13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. You are all done!
Hope this helps
Thanks
Oct 08, 2010 | Jensen XA2250 Car Audio Amplifier
DELL SPEAKER SYSTEM STOPPED WORKING
Suggest you abandon the mini-phone jack connection - sounds like a wire is broken in that connector. Use the RCA stereo outputs from your TV into the Dell surround system. You may need a couple of adapter cables to make that work. Take photos of the connectors on the back of your TV and on the back of the Dell Surround system. Take those to an electronics store like Best Buy and ask for help there to get the cables you need (telling them that the mini-phone (headphone) plug is giving you trouble.
Apr 22, 2017 | Dell 5650 Computer Speakers
Need wiring diagram
Step 1 Understand the basics of all car stereo systems. A car stereo system consists of 4 main components and the wiring that connects them. These are the head unit, the main speakers, optional amplifiers and the subwoofers, which are also optional but generally considered a necessary part of any good system.
Step 2 Know that the core of any car stereo is the head unit, which is the cassette or CD player that goes in the dash. All the other components are connected to the head unit by at least one pair of wires.
Step 3 Know about car speakers. The main speakers are usually 2 in the front and 2 in the back, although with what are known as component speakers, each speaker is broken down into two speakers: one for the highs and one for the bass. Each speaker or speaker set (known as a channel) connects to the head unit via a pair of wires. Generally if you are installing a new head unit you want to install new speakers.
Step 4 Know about amplifiers. Amplifiers provide extra power to your speakers and/or extra channels of power for additional speakers. The most common use for an amplifier (amp) is to power subwoofers. The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire. This article assumes the use of a single amplifier connected to a pair of subwoofers. If you do not have these components simply ignore the steps specific to the amp, doing so will not affect the rest of your installation.
Step 5 Know about subwoofers. Subwoofers are part of any good stereo system. They provide the deep bass that small speakers cannot achieve. Subwoofers are connected to the amplifier which can usually be mounted right to the subwoofer box. If you do not have subwoofers you can simply ignore the steps specific to them.
Preparing for the installation
Step 1 Be properly prepared. This is extremely important since you do not want to realize you're missing something in the middle of the installation.
Step 2 Purchase the following: A car stereo wire harness which connects the existing wiring for your old head unit to your new one (this will be specific to BOTH the model and year of your car AND to the make of your new head unit); an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
Step 3 Obtain a guide to removing the dash, doors panels (or whatever compartment the speakers are in), and floor molding of your car. You may be able to find a guide for this online. If not, you can get a repair manual for your car at most automotive stores and online).
Step 4 Gather the following tools: Screwdrivers to fit the job, pliers, wire cutters, wire strippers, a utility knife, sand paper or a file, electrical tape, a 9-volt battery, and any other tools that the instructions for installing the head unit and your car guides specify.
Installation Process
Step 1 Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
Step 2 Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Step 3 Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
Step 4 Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
Step 5 Put the fuse in the fuse holder.
Step 6 Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
Step 7 On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
Step 8 In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
Step 9 Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
Step 10 Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
Step 11 If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
Step 12 Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
Step 13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. That's all!
Good luck.
Mar 26, 2010 | Car Audio & Video
Lanzar optidrive series 4000watts mono block digital compitition class amplifier
Firstly, sorry to to tell you, but their is no such thing as a 4000 watt car amp. Google Ohm's law and RMS .
Check the owners manual or website to find the amps minimum impedance. Usually 4 or 2 Ohms. Next,
check the woofers impedance , If unsure check with a Ohmmeter,
It's actually the resistance,but close enough.
If they are 8 Ohm and you twist those wires together (parallel circuit) your amp will see 4 Ohms.
If they are 4 Ohms (paralleled) your amp will see 2 Ohms.
Do not connect in a series circuit (+ amp terminal to a + speaker terminal and that speaker - terminal to the other speakers + terminal and that speakers - terminal to the - amp terminal) .
It creates phase problems, and sounds like ****.
Most mono amps are really internally bridged stereo amps ,it's cheaper that way, but it limits how low of a impedance they will handle. Read the specs. Use the correct size connectors, scrape off paint for a good ground connection.Use the right gauge wire and above all. Fuse that power lead at the Battery!!!!!!!!
ps . if you have dual voice coils thats another chapter.
Good luck, Sumthin
Jun 11, 2008 | Lanzar Car Audio & Video
No sound
It's very likely that you have a factory amplifier in the vehicle that needs to be either turned on or (preferably) bypassed to get sound to the speakers. If your vehicle is a Mustang, it's almost certain that you have a factory amp. If the factory plug includes a long, 8-pin gray plug and a small, square 8-pin plug connected to a round cable, then the amp turn-on wire is at the opposite end of the gray plug from the constant power wire. This needs to be connected to the blue/white wire on the Sony head unit for the factory amp to turn on. Otherwise, if you dig into the radio cavity a little bit, you'll find a black 8-pin connector that looks very similar to the gray connector at the back of the radio. The black connector pins are connected directly to the speakers, bypassing the factory amp.
Mar 15, 2007 | Sony CDX-2250 CD Changer
120 people viewed this question
 Grubhead
Grubhead
