Question about Dayton Gas Furnace Heater
Dayton gas unit heater model # 3E368A in the wiring, what is the blue wire for
I have all the wires hooked up, but cant figure out where the blue wire goes
  • 579 Answers
SOURCE: Installing a Dayton G73
If that is a 240V unit then you are correct wiring L1 and L2 to black and red. Unless the unit uses 120V for something like a control panel, it doesn't need the neutral.
Posted on Jan 14, 2008
SOURCE: Lot of the wires came off the on the back of the Heater
We have a Dayton Unit Heater in the garage, gas. the wiring is a mess do you have schematics?
Posted on Nov 18, 2008
  • 108 Answers
SOURCE: Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Posted on Dec 07, 2008
SOURCE: Line voltage Tstat installation Dayton D-F79 elctric shop heater
If I understand your post correctly....You state that you are hooking up a 240v heater and towards the end you speak of removing jumpers...W2 terminals..ect. It sounds to me your trying to us a 24v low voltage thermostat instead of a Line voltage thermostat.That's what I'd take a look at.
Posted on Jan 21, 2009
SOURCE: hooking up my heater
The black goes to L1, Red to L2. The bare copper wire is the ground which goes to the grounding nut in the rear, it has the green washer on it. The white is the 'common' or 'neutral' wire and isnt used, it gets capped with a wire nut and some electrical tape.
Posted on Mar 10, 2009
Wire a dayton 4lz94a thermostat for turning on a gas fired heating unit?
If the unit has a switch that does fire it up when turned on. using the same gage wire, you can make an addaptor with an extention cord buy cutting just the black wire ing the extention cord and hooking the black wire from the male plug side to the line in side of the thermostat and the black wire from the female side to the load side of the thermostat..
Feb 12, 2015 | Dayton Heating & Cooling
My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Dec 12, 2009 | Dayton Heating & Cooling
Need ignitor and gas valve for heater
They sell dayton stuff at Graingers
Dec 04, 2009 | Dayton G73 Utility Heater
I just purchased an used furnace model # 4E458 and serial # Q9541564. I am trying to find a wiring diagrahm. Where can I get one? Thank you Joe Biernasz
if you go to the manufacturers web site they should be able to help. but most of the time you just need to hook up your high voltage(120v) which if your black, white and green. and on your low voltage side it is usually red=r,green=g,yellow=y and w=white. if you have a thermostat that is battery operated than you do not need a common wire. if you need a common wire than us the blue wire. and if you are hooking up an a/c system then hook up 1 wire to y and the other to common
Nov 10, 2009 | Dayton Gas Furnace Heater
I have installed a Dayton G73 heater in my garage along with a 240V outlet. I am using a 3 prong dryer cord and I am having difficulty figuring out which wire to hook to L1 and L2. I have determined the...
here's a link to the install guide
www.air-n-water.com/manuals/G73.pdf
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Installation-Dayton-G73-Garage.htm
Nov 02, 2009 | Heating & Cooling
I have a dayton furnace model 3e368a serial c8425580 wondering if it can be converted to propane?
yes it can you must change the gas valve and the converter to propane,may have to change orafice on burners.any good plumber can do this for you.
Jul 11, 2009 | Dayton Gas Furnace Heater
Dec 16, 2008 | Dayton (3E379) Heater
Hooking up my heater
The white is the common neutral, it is probably a 3 wire unit, and you are missing the ground wire. Check inside the control panel and see if someone wired it using the white wire for the ground, it will be screwed into a terminal lug. Check the schematics to see if the unit requires a common neutral to run the controls.
Nov 24, 2008 | Dayton G73 Utility Heater
Sep 23, 2008 | Dayton (3E386) Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Dayton Gas Furnace Heater Logo
79 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
