Question about Toshiba 43H70 43" Rear Projection Television
Toshiba 43H70 HD Projection TV
Hi, Hope you are doin well. Been having some trouble with my TV. Hope you can help me. The bottom third of screen is curved upward and the colors seperate as it gets to the center of screen. I go to the convergance menu and the green cross is above the red and blue and is tilted to the left. Took the green magnifier lens off and put screen back on. That fixed the curve or arche but of course the green is not focused. Then I covered the green gun and the picture is good but the green now is ommited making the picture very red. Does this mean the green/center color gun is bad or the magnifier lens? When you have a moment please let me know your thoughts. I would be very greatful for your help. Thanks a millon........Andre the old heavy chevy guy.
    Scholar:
  • 77 Answers
This is a convergence failure, there are hundreds of posts about it on this website you should be able to find everything you need
Posted on May 23, 2007
SOURCE:
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
Toshiba projection tv
Sounds like it blew an "Internal Fuse"
if you want to fix it..simply open rear of TV and look for the fuse.
here is link for a manual if you do not have one.
Mastersage
http://www.devicemanuals.com/guide/Television/Toshiba/Toshiba-43H70-User's-Guide-TVRNME9EUT.html
Feb 05, 2009 | Toshiba 43H70 43" Rear Projection...
Depending on the manufacturer of the cable box, there will be a menu somewhere regarding aspect ratio using the terms - cropped, zoom, and a few other terms as well. You probably want cropped, which will cut some of the sides off, but you wouldn't miss the picture as a whole when view at full screen. Hope this helps!
Jun 14, 2008 | Toshiba 43H70 43" Rear Projection...
Toshiba 43" Rear Projection tv (Just show's Blue Screen)
Hi Chris,
It sounds like you have a tuner problem. Usally the set will turn blue if there is no signal to the set, which is first generated from the tuner. It could also be the processor on the main board, but I would look at the tuner first.
Good luck and I hope this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
May 28, 2008 | Toshiba 43H70 43" Rear Projection...
Toshiba 43H70 - making it HD
you cant make it high Def. The converter only allows and analog tv to recieve digital signals, But it wont make it a HDTV
Apr 03, 2008 | Toshiba 43H70 43" Rear Projection...
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
128 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
