Question about Acer Aspire 5100 Notebook
Acer Aspire L5100 is not posting, no display and no bios beeps
  • 18 Answers
SOURCE: Bios reset on a acer aspire 1640z
To reset the bios in a laptop you need to unplug the power supply and remove the battery. Once you do that press and hold the power button for 45 seconds then put the battery back on and plug it in and then try starting it. Everything in the bios will be reset to the factory.
Good Luck
Posted on May 04, 2009
SOURCE: acer 1640z boots up fine, but no post screen and bleeps
Dear all,
I also posted this one under "Notebook Bios Problems" which might not be the correct place. Anyway here it is for you to see and maybe you can learn from my experience.
Have done a VISTA upgrade with Acers upgrade DVD.
It recommended to upgrade the BIOS - after doing this notebook is dead.
(1 long and 2 short beeps).
If I want to flash a new BIOS with Crisis method which BIOS should I use i.e. how do I know if I need the AT or UMA version - how to verify this on the notebook (my version is 1642 ZWLMI)?
I would very much appreciate some help on this - thank you
LATEST NEW - it WORKS AGAIN:
I was a little bit worried when I started icon_sad.gif but later I was all smiles icon_biggrin.gif icon_biggrin.gif
So a BIG thanks to everyone who posted possible solutions here in this forum:
1: I bought a NEC model UF0002 USB floppy Disk Drive Unit.
2: Downloaded the zip file from the ACER homepage with the BIOS
(chose the one that should be the correct version for VISTA:
It contains 2 WHP files: ZL9A3A24.WPH and ZL9I3A24.WPH as I
learned from NoClaim's post I chose the ZL9I3A24.WPH.
3: Downloaded the zip files with the Crisis recovery zip-file (See d0gi's
post: http://www.rechner.org/b1800.html ).
4: un-zipped the files
5: copies the file ZL9I3A24.WPH into the crisis directory - deleted the
BIOS.WHP that was allready there. And renamed ZL9I3A24.WPH
to BIOS.WHP.
6: ran the WINCRIS.EXE program (did an unbootable format of the floppy)
7: I now had a recovery floppy.
8: all steps above obviously done on my desktop PC.
9: removed battery from my ACER 1640Z laptop
10: unplugged powercable.
11: inserted the USB floppy in one of the USB ports on the laptop
12: pressed the <fn> and <esc> keys
13: plugged the powercord
14: Turned on the laptop
15: waited a bit - lights came on on the laptop (no beeps)
16: waited a little longer and the light on the floppy came on
17: waited still a bit longer until I could hear the floppy was working
and then I let go of the keys <fn> and <esc>
18: after a while there was no activity on the floppy any more and
shortly after the laptop shot down.
19: the laptop started up again on its own and IT WORKED
20: THE LAPTOP IS BACK AND THANKS TO ALL OF YOU I SAVED A LOT
This worked for me and only cost me £5, Here is the web sit i got it from
http://www.wimsbios.com/phpBB2/topic9512.html
Hope it works for you
Tony Swannell
Posted on Jan 13, 2009
SOURCE: Acer Aspire 1640Z BIOS problem
Dear all,
I also posted this one under "Notebook Bios Problems" which might notbe the correct place. Anyway here it is for you to see and maybe youcan learn from my experience.
If I want to flash a new BIOS with Crisis method which BIOS shouldI use i.e. how do I know if I need the AT or UMA version - how toverify this on the notebook (my version is 1642 ZWLMI)?
to BIOS.WHP.
hakimmadina_
  • 155 Answers
SOURCE: acer aspire 9300 black screen (display adapter)
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
Posted on Jun 21, 2009
drifterK
  • 4924 Answers
SOURCE: acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
Posted on Dec 21, 2009
Why does my Acer Aspire L5100 not have sound trough the HDMI cable?
It may have, but may not be enabled. On Windows PCs, you may have to go to the Control Panel and go to the SOUND tab. There you may find that you have to choose between the default analog sound out and the digital sound output thru the HDMI cable. If your system has an audio manager application (Realtek for example, uses one), you can select the digital output there as well. It may even be easier to do there.
Mar 04, 2015 | Acer Aspire L5100 (4496426) PC Desktop
Computer beep codes
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Bios beep codes to many popular brand systems are given.
Aug 05, 2014 | Acer Aspire 5600U all-in-one desktop
I have no screen on my acer aspire 9300 it powers up and then I get three beeps the first longer than the second two and then just a blank screen?? Please help
When you hear some beeps before a computer boot it means that it didn't pass the POST (Power On Self Test) phase. Taking note of the sequence of the beeps and checking the manual should tell you the reason, for example bad memory, no HD found, bad processor, etc....
Looking at your model manual here below the codes are not indicated but Acer ask to call their tech support (see page 43)
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS%209300_7000%20User%20Manual.pdf
Anyway the 1 beep long and 2 short means 1 long, 2 indicate a video error and the Bios cannot initialize the video screen to display additional information.
You may have to replace the video card.
regards
Mar 16, 2011 | Acer Computers & Internet
Every time i install windows 7 in L5100 acer desktop after some days it will show recovery it will nwver recover what is the problem
Have you deleted all partitions on disk, also the "hidden" partition
where backup is stored, before you install W7?
May 21, 2010 | Acer Aspire 5100 Notebook
Acer Aspire One continuous beeping at power on, until Windows screen comes on
Need to check the BIOS beep codes but I'm fairly sure that continuous beeping on boot is a display adaptor card issue. If you don't see anything on the screen until that point it may be something is set wrongly for the display within BIOS and it can't sort it out until Windows takes control of the system.
Oct 11, 2009 | AcerPower Sn PC Desktop
Acer Aspire 9303wsmi display problem, 1 long beep, 2 short. HELP!
What you hear are bios beeps. They signal you that something is wrong. These beep's vary by the manufacturer of the bios chip that you have.
You can find out what bios you have by looking at your manual. The common cause for one long and two short beeps is a video problem.
Either the video chip on your mobo is shot, or your video card needs attention.
Hank
Aug 04, 2009 | Computers & Internet
Acer aspire L5100
Just what is it you need help with? The Acer came with a quick start guide.
You received a manual with the PC, start by reading it. If there is something that you do not understand just post you're question's here & one of us will find you an answer.
Mike
May 07, 2008 | Computers & Internet
Screen went out on my Acer Aspire 5102WLMi
as per your information your display adapter(if onboard) or video card is defective.replace it
Apr 02, 2008 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5100 Notebook Logo
1,501 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
