Question about Indesit W 123 Front Load Washer
How to remove front panel Indesit wm12x - Indesit W 123 Front Load Washer
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: I need to replace a washing machine door seal
It would be adviseable to rempve the top, and also tilt the washer to the rear, as it makes it easier to change the seal, and gives you more room to get your hands in.
Please rate my comments.
Thanks.
Posted on Oct 30, 2009
Testimonial: "Prompt and accurate feedback. Many thanks."
barkencoa
  • 3463 Answers
SOURCE: manual for intergrated indesit wm12x washing
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Posted on Jan 13, 2010
barkencoa
  • 3463 Answers
SOURCE: my dial keeps clicking round
I doubt it will solve the problem, as the part you are referring to is a selector switch and not the timer, the problem is more likely to be a faulty control unit.
Posted on Nov 19, 2010
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
I have a indesit wm12x washing machine and i was told it is a dryer but i can not get it to work please help
I have been looking at your machine on internet and found out that the indesit model you have is not the washer dryer version it is a washing machine so has no dryer function. hope this helped.
Sep 19, 2010 | Indesit W 123 Front Load Washer
Manual for intergrated indesit wm12x washing machine
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
I need to replace a washing machine door seal (indesit wm12x). Do i need to remove the top or can i do it from the front ? Any other tips on the procedure would be great. Thanks
Thanks.
Oct 30, 2009 | Indesit W 123 Front Load Washer
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
TEAR IN SEAL ON AN INDESIT INTERGRATED WASHING MACHINE...MODEL NUMBER WM12X. IS THIS EASY TO FIX,THERE IS ALSO MOULD ON IT...MAKING IT SMELL, ARE THE PROBLEMS LINKED ?
the fitting of the seal depends on the age and wether the tank assembly has been changed as there were two different fixings one was a spring fitting and the older version was a clamp which requires a tool to fit.
the mold is rotting washing powder which can be reduced by putting a cleaner through once a month.
Aug 05, 2009 | Indesit W 123 Front Load Washer
Help!! Indesit WM12X - cold wash only
Yes, they are easy enough to replace, but you need to test them with a multimeter to see if they are faulty..
There could be other things wrong.
Nov 22, 2008 | Indesit W 123 Front Load Washer
Wm12x drum stopped
It's probably the bearings. The drum have probably get so loose from the bearing, so the belt have snapped off.
Jan 28, 2008 | Indesit W 123 Front Load Washer
Filter on indesit washing machine
Push panel right or left side. Unscrew or turn anti-clock wise, according to your model. Be prepared for some water. Pull this out and clean, refit carefully. Of course it is meant to be removed and cleaned periodically, according to usage. Rate me pl.
Nov 30, 2007 | Washing Machines
INDESIT WM12X
brushes in your motor almost certainly, put your meter across the motor you will find a open circuit failinf that your control module could be damaged
Apr 21, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
26 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
