Kenmore Elite 970-C41074 - Washing Machines
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Model 970-C41074-00. Front Load
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
  • 6277 Answers
SOURCE: I have a Kenmore Elite
(start here!)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 02, 2011
Kenmore c-970 setting clock
Tap Clock sign (cooktop lockout) then ->
Enter time 8 - 3 - 7 for 8h37 ->
Tap "Start"
Done...
Mar 24, 2014 | Kenmore Elite C970 440935
Kenmore freezer,model # 970-155320
How much cold can this kenmore 970-155320 be,it need to be....
  • A freezer that is at or below 00F (-18oC) i wanna use it for bed bug killing.....
Jan 04, 2014 | Kenmore Freezers
I have a Kenmore Elite 970-C41074-00 Front load washer that makes an extremely loud noise when it goes into spin mode. I was hoping you could tell me what the problem could be, and a possible solution....
(start here!)
John C
May 02, 2011 | Washing Machines
Can you stack a kenmore washer / dryer model # 970-c84102-00 and 970-c44102-00?
  • yes you can stack 970 c84 10200 mine is. I just wish i could repair it, first youe have to take the cover off and thats as far as i got
Oct 19, 2010 | Kenmore Dryers
Kenmore elite range, model 970-698593, Error Code E015
Just asking if your model number is correct. I do not find 970 models but do find 790 models. If it is a 790 model there can be aproblem with the door lock on the oven door. You may want to check to see if all the shipping materials have been removed from the door lock / latching area. I would recommend that you review the installation instructions in the owners manual, paying particular attention to the removal of shipping materials.
Adittionally if the problem presists it says to replace the Electronic Range Control (ERC) This is not a cheap part! Good thing it will be at their expense including the repair service call..
Hopefully you have already called for warranty service? We both know a brand new oven should not be producing any error codes. If you have not called for warranty service you do so now. Make sure to tell them that you already have talked to customer support and that unplugging the unit for ANY period of time made no difference in the error code.
Thanks for choosing FixYa.
Kelly
Aug 01, 2010 | Kenmore Kitchen Ranges
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Model 970-C41074-00. Front Load washer will not start. Electrical power checked and OK at washer plug in. Dorr shuts fine and the soap dish shuts fine. Whren set to wash and knob pulled out...
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
