Question about Whirlpool ADG332 Built-in Dishwasher
ADG 6956 power button flashing 2 times - Whirlpool ADG332 Built-in Dishwasher
4 Suggested Answers
  • 90 Answers
SOURCE: CODE F4 and washer not working
Not too sure on that code, could be timer error. One thing to try would be to turn off the AC power to the unit and let it stay off for 15-30 minutes and then turn it back on. Sometimes if the unit takes a voltage spike it hashes the memory and resetting the power will clear it up, but to do this the voltage needs to turned off at the fuse/breaker box and not just the switch on the front. If you have the manual it may give ideas. I could not find the model no. you listed. Check to see if it is correct if resetting the unit doesn't help.
Posted on Feb 03, 2008
  • 901 Answers
SOURCE: Whirlpool ADG 6556 flashing code
Refer user guide for the correct meaning!
Meanwhile Check all the dispensing compartments- salt - rinse-aid, free inlet water flow and the door close.
Posted on May 21, 2010
ercupa190
  • 12223 Answers
SOURCE: whirlpool adg 155 eco button flashes
see this causes and use the common sense. God bless you
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check for 120 volt at the power box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi limit fuse.
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch. The power comes into the main power box and usually runs to the door switch next before entering the main control module.
Main Control Module / Timer
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the control module, this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor. Make sure the motor is recieving power.
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace. We have video and tutorials that cover several styles.
Posted on Sep 20, 2012
Whirlpool integrated dishwasher model ADG 7460 Have run the engineer test cycle and it stops and drains water after 2 mins; start light blinks 5 times.
F5 or 5 times flashing.
Variable speed motor failure.
Reason:
- Connection between Spray pump (Variable speed motor) and control board interrupted.
- Frequency converteron Spray pump broken or control board defective.
= Check the power voltage on the motor. BUS: 5V DC, Motor: 230V AC
Reaction: Cycle stops, drain pump drains out,failure indication.
OR
SPM blocked (MPH motor unit)
Failure condition:
- This failure is only indicated during the active test program
- The electronic detects an irregular deviation of the motor current consumption.
Reason:
Spray pump blocked = check pump housing
Short circuit in motor or wiring = check motor values
Reaction: After 5 attempts to reactivate the spray pump motor the cycle stops, drain pump drains out, failure indication.
Dado
Sep 03, 2015 | Whirlpool Dishwashers
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
May 20, 2010 | Whirlpool 24 in. ADG6552 Built-in...
Reset control panel for Whirlpool ADG 4952
whirlpool adg4952m is reading F2 and not working
Jul 04, 2009 | Dishwashers
Purple blotch on screen
hi..This patch can be a result of your TV 's Auto Degaussing
Coil problem. Metallic parts of a TV gets magnetized and the
ADG coil demagnetizes them. At power on you should hear a
sound,which is the ADG coil.please check the ADG coil connector
it might have been pulled out. The ADG coil is wrapped around securely
on your TV's Picture tube and power is tapped directly from the AC
Main via a plug in type connector to the TV main circuit board.
check it out..
thank u..
rate me..
May 04, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Whirlpool ADG 957. Light for rinse programme on but start light flashing intermittently. Cannot change programme, cannot start machine.
Mine was doing exactly the same. I turned off power, held down the 2 black buttons on right, switched back on and the start button flashes intermittently. It then allowed me to change programs, just testing it now!! It started, this was more then it was doing!! lol
Aug 17, 2008 | Dishwashers
Feb 01, 2008 | Whirlpool 24 in. ADG6962iX Built-in...
F7 error
Raise your water supply temerature. Next open door and within 3 seconds hit hi-temp scrub, then energy saver. Do this again. Close door and latch, then push reset button.
May 22, 2007 | Whirlpool 24 in. ADG7952 Built-in...
Whirlpool ADG332 Built-in Dishwasher Logo
54 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
