Question about GE GSL25JFPBS Side by Side Refrigerator
Find defrost timer on ge refrigerator model gsl25jfpabs
  • 184 Answers
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Posted on Apr 10, 2008
MNTECH
  • 1543 Answers
SOURCE: freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Posted on Dec 26, 2008
peyton32034
  • 410 Answers
SOURCE: Where is the defrost timer located on a GE model
The defrost contrlol is located behind the light lens cover in the fresh food section. it is to the far right side of the control console.
Posted on Mar 01, 2009
  • 93 Answers
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
Posted on Mar 15, 2009
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
Ge defrost timmer location gss
DEfrost timer is placed beside compression unit, behind refrigerator.
Jul 04, 2013 | Refrigerators
Where Is The Defrost Timer Located On My Ge Refrigerator Model GSL25JFTABS
Where is the defrost timer in my General Electric freezer model number PSS26NSTB SS
Feb 28, 2013 | General Electric GSS22JET Side by Side...
Ge profile refrigerator PSF26PGTB defrost timer
your defrost timer on this model is an ADC type timer(automatic defrost timer) and is located on the mainboard in the lower rear on the back side of the unit,its part # is WR49X10152
Aug 25, 2012 | GE Refrigerators
Where would i locate defrost timer on my ge bottom freezer refrigerator
Older fridges use a defrost timer to control when the fridge goes into defrost. Yours is a newer model and uses a control module which controls all of the fridge's functions including defrost timing. It does not have a defrost timer. It cost around $150. But I would check the defrost element first. A lot of problems with the defrost are usually a burnt out heating element. Use a meter and check that the element is not electrically open.
Dec 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Is the ge tbx19 defrost clock continious or cumulative?
The timer will advance whenever the cold control is on. (when the compressor is running, or the timer has advanced into a defrost cycle) When the refrig is cold enough (and the timer has not advanced into defrost) the timer will not be advancing. A typical defrost timer will count up 8 hours of compressor run time before going into a 30 minute defrost cycle. (the run time and defrost time can vary greatly from model to model)
Jun 16, 2010 | GE Profile 19.0 cu. ft. Top Freezer...
Our GSL25JFPABS Side by side refrigerator door Water not working
water valve problem. behind the fridge. 3 or 4 screws .2 water lines. really simple.
Mar 31, 2010 | GE GSL25JFPBS Side by Side Refrigerator
I have a GE Model #GSL25JFPABS fridge. My freezer has been frosting up for quite some time with the ice cubes melting a bit and freezing together. Recently the fridge side has also been warming once in a...
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 29, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Where is the defrost timer located on ge side bty side model gss25jfmdww
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
Need location of defrost timer
The refrigerator you listed does not have a defrost timer. All defrost and refrigerator functions are controlled on rear of the refrigerator. It's called a mother board. If it s damaged you will sometimes see burns on one of the both sides, but not always. Another problem could be that your defrost element or defrost thermostat is defective. You can see your refrigerator below by putting the model GSS201EMBWW into the model search feature. I am here to help you if you want, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Here is another link here on FixYa that shows the mother board
http://www.fixya.com/support/t230703-ge_refrigerator_stopped_working
May 28, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GE SxS GSL25JFPABS freezer will not freeze
When the refrigerator is running ( cooling mode ) the defrost timer contacts prevents any power from getting to the defrost heater. When the defrost timer turns off the power to the compressor and fan motor(s) the power is then redirected to the defrost system. The defrost timer motor
Defrost thermostat:
During a defrost cycle, the defrost heater causes the metal alloy in the switch to warm and as it does it curls back and breaks the circuit. As the metal cools, it makes a closed circuit again. A defective thermostat can prevent the defrost heater from coming on or allow it to overheat which could result in heat damage or fire.
The defrost thermostat is located near the defrost heater and is wired in series. It is usually located at the back of a side by side freezer, behind the freezer back wall of a top freezer or under the floor. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer. At room temperature the defrost thermostat is an open circuit ( no continuity ) and when cooled down the defrost thermostat closes the circuit ( has full continuity ) to allow the defrost heater to come on.
Feb 26, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
