Question about HP Pavilion dv4000 Notebook
Faulty Connection I have an HP Pavillion DV4000. The power seems to have stopped and I have tried with new AC adapters to no avail?, I know the battery is fairly useless and needs replacing but this shouldnt make a difference should it? any suggestions
  • Anonymous Jan 09, 2009
    I have the same problem.. I've tried new AC adapter. I think the problem is with the internal power supply, possibly the mother board.
    Problem Solver:
  • 16 Answers
I have HP DV6000, I used it without the battery. it worked until I was able to purchase a new battery. It might work on the HP dv4000...
Posted on Jan 06, 2009
Hp pavillion lighitng bolt led on front keeps flashing and will not power on
I see that you said that you "powering on the AC adapter only".
Does that mean you tried booting with the battery removed?
If not, completely remove the battery and try to boot.
If that fails too, it will be a switch or board issue
Mar 12, 2013 | Computers & Internet
HP Pavillion dv6700 - won't power up
Hi have you tried to power up without battery?
Feb 16, 2013 | HP Pavilion Computers & Internet
The power adapter that plugs into the laptop HP DV4000 is broken, and I can't use the charger. where can I find a new one to replace the broken one, or will I have to buy a whold new charger? thanks
Do you mean only the power cable that linked the power brick with laptop was broken? Of course if you are 100% sure that's the only part that fail, you may only buy a cable. Check this link blow:
http://www.chargerbuy.com/cable-connector/power-cord.html
But if you are not that sure, i'll suggest you buying a whole new charger:
HP Pavilion DV4000 AC Adapter
Aug 03, 2010 | HP Pavilion dv4000 Notebook
My HP Pavillion DV6000 laptop starts up fine and after a few minutes the screen turns black. I can still see the desktop image in the background but barely. If I reboot the screen looks normal again but...
That means your backlight is going out. The fact that it's happening intermittently like that suggests that you have a faulty screen inverter (a small circuit behind the screen that converts DC power to AC, in order to light the florescent backlight).
I suggest replacing it. Here are some on abay for pretty cheap:
http://shop.ebay.com/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A2608&_nkw=Pavilion+dv4000+inverter&_ipg=&_sticky=1&_trksid=p3286.c0.m14&_sop=15&_sc=1
Mar 24, 2010 | HP Pavilion dv4000 Notebook
I bought a new ac charger for my hp pavillion dv1000 it will not power on
Check and make sure the Voltage on the AC adapter is the exact same as your previous one. Just because the connector fits in the port, doesn't mean it's the right one. Look in your manual to figure out if your AC adapter voltage is correct. If it is, it's possible that you have a dead battery, it happens when surges happen during power outages. If it's so, look on the HP website for a new replacement battery. It should allow you to type in your pavillion model number.
Jan 08, 2010 | HP Pavilion dv1000 Notebook
Hp pavilion dv4000 screen wont turn on
Try this quick fix first. Remove the battery, unplug the ac adapter and hold in the power button, plug the ac adapter back in and turn on.
Jun 20, 2009 | HP Pavilion dv4000 Notebook
I have a HP Pavillion DV4000 and it does not charge
pls check if it runs ok during power supply AC and also check Battery contacts on both side laptop side and battery contacts see if rust or residue is sticking there try to scratch it out by some rust removing cream or something normally it happens other wise if the adapter supply is ok AC one then ur battery is faulty try replacing it there is a battery checking utility on HP support software try it , i think it will help u cjeck the batt
pls rate me if i fixed it
Feb 27, 2009 | HP Pavilion dv4000 Notebook
Ac adapter for hp pavilion ze 4900
Go to spare parts shop you can resolve your problam with min price
Jun 13, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Battery charging
Does the machine boot and work just on AC?
If it does then you may have a bad battery - Does the old battery charge?
If it does not work on AC then try another AC adapter - even the generic universal kits should be enough to test it.
hopefully that's all thats wrong. let us know.
Dec 27, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
103 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
