Question about Irons
Rowenta dis assembly pix
Read your post and would like to see the pictures.
I can get the part I need, auto shut off for my DE 635, but there is a screw holding the front of the sole plate which I domn't want to break...as you seem to have done. They probably use similar construction on all their models.
Thanks
  • melampus2 Jan 06, 2009
    Thanks for the feedback.
    I fiddled some more on my own and was able to find the access for the front...it was a screw hidden by the spray nozzle assembly, which I was able to remove by popping it out, it was a friction fit with plastic nubs. Nothing broke, and I am now able to replace the shut off/ wire assembly. I found it on line and was just about to order it. The first time you take something apart you learn alot.
  • melampus2 Jan 07, 2009
    Now that I have completely dis assembled and put it back together, if I had to repeat, it would take about 5 minutes.
    There was an additional problem with my unit, with the (I'll call it) thermostat stack , which is connected to the sole plate. There is a metal finger which should make contact with a rounded post top,also metal, in order for juice to go to the heating element. It took about half an hour to figure it out..... dont know why there was a gap between the parts....maybe there was a spot weld that broke, but I don't think so. It occurs to me that it might be as an additional safety feature/interlock or thermal overheat shut off that failed. Anyway I bridged the gap so contact was made, and now the unit heats up, and the ON light goes on as it is supposed to. My unit was a DE 635, also labeled P2 on the plastic cover.
    The key to opening up this unit is the screw hidden under the spray nozzle assembly, which pops out if you are careful. The screw has a black plastic rectangle under it. This, plus the two obvous one on the bottom rear, allows the entire handle with all the auto off stuff to lift up off the iron. The water reservoir, etc lifts off, then you can remove three more screws to get to the sole plate and the thermostat if you need to. Those parts don't seem to be available. I won't get into the wiring other than to say there should be continuity between the right most( as seen from the rear) wire to the heating element and the other two for it to work.
I had a similar problem, my wife dropped the iron and it started leaking from somewhere inside even when the iron was not in use. I used this article to help me figure out how to take the iron apart and then found that there was a rubber seal that runs around the water chamber. I took a jewelers size screwdriver and used this to reshape the rubber seal that goes around the base of the water chamber... It stopped the drip and the iron works great now... thanks.
Posted on Aug 27, 2009
    Problem Solver:
  • 4 Answers
I have submittted the photos to one of the expert gurus on fixya and I cannot remember his name. If I remember correctly it is not a screw but a plastic pin (3) that sticks up fom the plate and is secured by a circular disc with fingers in the center that push up when they slide it on and one must open these fingers up, unuslly one will do so it will release. If you try to force it off it will/may snap off the pin. If some one can help you, you might want to get two of those $1.00 screwdriver kits and have one person, or a vise, hold the iron and the two of you slide the small flat screwdrives under the fingers and pry up together, if you can get to it. Remember the one I had was glued together with minimal screws throughout.I have never seen an appliance so difficult to access for the simplest repair. Good luck and God Bless.
Posted on Jan 05, 2009
  • Bill Black
    Bill Black Jan 06, 2009
    Happy or you. I am seeing a lot of problems with this $100.00 dollar iron frm request on fixYa and that bothers me as it is a great iron if ya don't drop it, bump it, etc. It is shameful that Rowenta will not release a repair manual for their irons for all the intillegent entrepenuers in the USA.
Switch not working hoe can i replace
Good evening Melinda!
You can look here for replacement parts
Rowenta DG5030U0 B80 Pro Master Iron Parts , (amongst others), and a closer look at the 'Housing, front complete'
Housing Front Complete shows it includes an on/off switch.
It's not a 100% match, but this video showing dis-assembly / troubleshooting another Rowenta iron will probably get you to where you need to to replace the part (and might allow you to see if it's just a disconnected/broken wire and save the $17 for the part!)
Hope this helps, and good luck!
D
Nov 19, 2015 | Rowenta DG5030 Iron
I have an older (1997) Rowenta DE 11 Powerglide iron. In the process of cleaning it, I mixed up the order of the wires. The colors are brown with the power cord, dark blue with the power cord, blue by...
If you can take a sharp picture of the circuit board and send it jodamechanical@aol.com I might be able to help you.
P.S. Make sure all wires and circuit board are clear.
Feb 10, 2011 | Rowenta Powerglide DE011 Iron with Auto...
Iron cuts off in the middle of ironing
It is probably an intermittent cord connection next to the strain relief. You can simply remove the back cover, cut the cord, pull the remaining cord (approx 6-8") and reconnect it. You can also order part # RS-DE 245954 the whole cord assembly including the circuit board for about $25.
Apr 17, 2010 | Rowenta Irons
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Wiring diagram for Rowenta DE-05
I have a DE-05 that needs a new cord and cleaning of steam discharge holes. I'll be gald to take photos and send them to you if you'll share your source for parts and method of disassembly. Contact me at chuxbizAThotmail.com, just replace the AT with @.
Thanks,
Chuck Jones
Apr 12, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Rowenta SM700
YOU HAVE TO READ THE SOLUTIONS
Jan 30, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Rowenta iron manual needed
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
Jul 24, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta powerglide 2
Rowenta DE-09 will not turn on. Plug it in and nothing happens. Is a fuse blown or some problem similar to that happening? Thanks
Chirs
3324747@gmail.com
Jul 08, 2008 | Rowenta DE09 Iron with Auto Shut-off
Irons Logo
545 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
