Question about Optoma Projector Multimedia Projector
IMAGES COMING UP BLUE
I just hooked up my Optoma DV11 projector and many images (color of peoples skin) and most things that are yellow (first down marker in football) are coming up blue.  I tried many different adjustments and hours later I am still stuck with the same problem.  Does anyone have a suggestion.
Thanks
Marrie
  • 563 Answers
SOURCE: Optoma EP 732H Blue/purple tinge
Hi jmm521
Try using a different VGA cable as connection - WILL solve your problem !
Thanks for using Fixya !
Posted on Apr 30, 2008
  • 3 Answers
SOURCE: color problems
i don't know if this will work but..... I have an Optoma h27 and we were having problems with the color and ours is mounted on the ceiling in inverted also; and after two years we started having color problems, come to find out that on the menu there is a option for high altitude and that had been turned to the "off" position (probably by our kids resetting all the options and not turning this one back on)..... after taking it to a tech that cleaned it for $97.00 and said there was no problems he could find, we played around with the remote/menu and came across this high altitude option and when we saw it was on the "off" position, we put it to the "on" position and another fan inside the projector came on and that helps to keep the inside of the projector cool at all time and helps from the color becoming weird..... Try this on yours and hopefully that will solve your problem.
Posted on Dec 22, 2008
projdoc
  • 2237 Answers
SOURCE: Why would my Optoma DV11 projector only have black
either the settings are off (reset them to factory default) or your colorwheel needs to be replaced. try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Nov 24, 2009
SOURCE: blotchy colors on optoma hd80
i had, have the same problem i also replaced the bulb then shortly after the power went out no standby light or anything. From what i've read so far it seems like a power supply issue so i ordered two power supplys from optoma 1 for lamp 1 for the unit waiting on delivery from CA they were $ 99 each if this work i'll be one happy camper. Three years no problems it's a great machine with incredible picture using 106" screen
Posted on Jan 29, 2010
  • 4234 Answers
SOURCE: optoma projector is displaying a green shadow to
This is a convergence problem that is not likely to be fixable without some test equipment. Check the menues for a convergence adjustment. You don't specify the model, so I can't provide any details here. If you can post the model number, I may be able to assist further.
Dan
Posted on Jun 24, 2010
Why wont my optoma dv11 dlp projector play new dvds
YES REPLACE THE LASER ASSEMBLY YOU WILL NOT GET IT FROM OPTOMA THEY WILL CHARGE THE EARTH FOR THE REPAIR BUT I KNOW WHERE IT IS AVAILABLE BUT YOU WILL NEED TO SETUP THE EYE PATTERN AND TRACKING.
john
www.jvsvisual.com
Apr 14, 2013 | Optoma "DV11 MovieTime DLP Projector"
My optoma projector has a green tint
it may just need a service, as all DLP projectors need to be cleaned internally as well as LCD.
DLP projector images will flicker and lose colour also may shut down if it is very dusty inside.
Jan 28, 2013 | Optoma Office Equipment & Supplies
DVD DRIVE WILL NOT OPEN ON DV11 OPTIMA PROJECTOR
Check if the drive is jammed, failure of the motor or a possible failure of the power supply to the drive.
You will need to remove the panel to confirm before any action can be confirmed.
Nov 04, 2011 | Optoma DV11 Projector
My image is een upside down and the projector gets heated up
change setting for projetor to turn picture upright -should be called "mirror" or something like that in on screen settings
all projectors run very hot so dont worry about that as long as you hear fans goin it should be ok
just make sure filters/ screens for fans are clean
Mar 21, 2011 | Optoma DV11 Projector
I only have 5 speakers and subwoofer of hts3450. how do I connect these to optoma dv11
You don't...
http://www.retrevo.com/support/Optoma-DV11-Projectors-manual/id/3239bh149/t/2/
The speakers will still need their electronics to operate from the audio source.
Proprietary connectors are a clue that the base and the speakers are a set not to be mixed or matched with standardized audio components.
Feb 05, 2011 | Philips HTS3440/37 System
Optoma projector HD806
its not the color wheel. Its the sensor that counts the black tape on the color wheel. The sensor has dust on it. It can't count how many times the wheel is going around because the dust is blocking it. the sensor is located by the wheel. if you have any questions you can callme 610-842-7442 ask for dan.
Dec 01, 2009 | Optoma hd806 DLP Projector
Why would my Optoma DV11 projector only have black and white picture now?
Nov 24, 2009 | Optoma DV11 Projector
I have an optoma dv 11 and need to find a main board. can anyone help me? the part number is 85E02G001 rev 2 thanks.
if you have an optima movietime dv11, the part # is actually 70.85E40GR01. try av solutions in ny. they can get it. www.avsolutionsny.com
Nov 10, 2009 | Optoma MovieTime DV10 Multimedia Projector
Hi jmm521
Apr 29, 2008 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Blue color
Bad contact on cables probably
Apr 03, 2017 | Sony VPL-ES2 Multimedia Projector
19 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
