Question about Kitchen Ranges
Robinhood 2001 rangehood manual
Manual
2 Suggested Answers
Controlfrk
  • 304 Answers
SOURCE: I require a circuit diagram for the electonic
The Link Below will take you to their website archive page. You will need the exact model number, with all numbers and letters, from the plate on the unit (Probably inside the vent filter). Click on "Please select a model" and choose your model from the drop-down list and three links will appear. One will be the "Parts and Service Manual PDF" Clicking on this link will give you the wiring Diagram.
Good Luck
Robinhood
Posted on Sep 06, 2009
How to replace capacitor on RHCV9G robinhood rangehood
Out with the old and in with the new. Just to be safe discharge the old one with pliers.
Aug 31, 2017 | Kitchen Ranges
How do i replace the lightbult in the robinhood 2000 rangehood?
It depends on the model but Instructions can be found in the operating manual that came with your rangehood or as a PDF on the product pages of the website
http://www.Robin Hood.com.au
Jul 12, 2014 | Kitchen Ranges
Where to buy replacement taps for rotec supertub
Check out this web site for free service manual with all infohttp://www.robinhood.co.nz/obsolete_product_downloads/Robinhood_ST1600_Parts_services.pdf
Jun 05, 2014 | Washing Machines
Service manual for rangehood
I asked a electician, it caused by start up capacitor fail.
Jan 14, 2010 | Frigidaire PLHV42P8CC Kitchen Hood
How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Nov 17, 2009 | Kitchen Ranges
I require a circuit diagram for the electonic controls of a Robinhood 9000 series rangehood
Good Luck
Robinhood
Sep 06, 2009 | Kitchen Ranges
Looking for a manual for SMEG rangehood HACD60SS model bought in 2008. Rangehood may not be installed properly, it's not sucking up air into the hood.
check to be sure that the fan works, and if it does check to be sure that the air flow path to outdoors is not clogged. one way to do this is to remove the hood and slide a dry garden hose through the entire vent pipe to the outdoors.
Jun 29, 2009 | Kitchen Ranges
Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
May 13, 2009 | Faber Perla 602599 Kitchen Hood
Change light bulbs in rangehood
I found the instruction manual on the Baumatic website.
Thanks anyway
Apr 18, 2009 | Kitchen Ranges
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
Kitchen Ranges Logo
473 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
